Ok I'm trying to organise a cruise for either Friday or Saturday. Not going to be a slow drive, so those who are interested in a really good drive, please leave a message.
Also please tell me a prefered time and day. Right now im thinking 11pm meet on Saturday.
ROUTE: Higher Speed runs, Corners, DRAGS.......................
ANZAC HYW, EAGLE ON THE HILL, MOUNT LOFTY, FREEWAY, Etc etc.................
https://www.sau.com.au/forums/topic/27526-cruise-anyone/
gee N/A with a post like that do you really expect a night of cruising without incident? and posting your planned route sounds like a real good idea buddy. Theres a lot of ppl giving car enthusiasts a bad name up here in NSW at the moment, its ppl like you that are really pissing off the public/police etc etc giving us all a bad name. Are you 18, on P's and drive a Silvia Q?
https://www.sau.com.au/forums/topic/27526-cruise-anyone/#findComment-577040
Yes, nothing wrong with that is it?
Also, i'm wanting a good cruise where you have a chance to give it a little. For example, I have never driven up Eagle on the hill slow.... this doesnt mean i will be driving like a maniac every where...
It is no different than driving fast through black wood or dragging a 200sx on ANZAC. But this way, you get to more people to join in the fun. :)
SO DONT MISUNDERTAND what kind of cruise i mean
https://www.sau.com.au/forums/topic/27526-cruise-anyone/#findComment-577141
Originally posted by BOOSTD
You got it all wrong, N/A drives a turbo gemini stationwagon. It's fullysic
Oh comeone man, now the coppers are gonna know who i am.
So you up for another drive this week? If your mate with the gtr 33 decides to come out, let me know so i know wheter to drive the gemini or silvia Q :D
https://www.sau.com.au/forums/topic/27526-cruise-anyone/#findComment-577865
Baahhh, you guys have got no chance if I bring out the Sigma! 2.6 litres of raw ground pounding ggggrunt, well, at least 30 or so rwkw up to 3k & then she's as breathless as an 80yr smoker with a collapsed lung :(
https://www.sau.com.au/forums/topic/27526-cruise-anyone/#findComment-578516
Your sigma might get me at the end simply because mine is a station wagon and heavier. STEALT MAN!!!
My gemini makes 0ver 47kws @ all four wheels. But I cant get it tuned with the Power FC because I dont trust anyone in SA. Just incase the motor blows up. Any recommendations?
https://www.sau.com.au/forums/topic/27526-cruise-anyone/#findComment-578554
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
    • Well this shows me the fuel pump relay is inside the base of the drivers A Pillar, and goes into the main power wire, and it connects to the ignition. The alarm is.... in the base of the drivers A Pillar. The issue is that I'm not getting 12v to the pump at ignition which tells me that relay isn't being triggered. AVS told me the immobiliser should be open until the ignition is active. So once ignition is active, the immobiliser relay should be telling that fuel pump relay to close which completes the circuit. But I'm not getting voltage at the relay in the rear triggered by the ECU, which leaves me back at the same assumption that that relay was never connected into the immobiliser. This is what I'm trying to verify, that my assumption is the most likely scenario and I'll go back to the alarm tech yet again that he needs to fix his work.      Here is the alarms wiring diagram, so my assumption is IM3A, IM3B, or both, aren't connected or improper. But this is all sealed up, with black wiring, and loomed
    • Ceste, jak se mas Marek...sorry I only have english keyboard. Are you a fan of Poland's greatest band ever?
