Hi fellas,
Like the topic says I am selling an Hks twin power module with harness ( for gtr r32 only ) and a nismo short shifter kit.
Reason for selling I have upgraded to a better computer. The hks module is pretty much brand new haven't tuned the car since it went on its only done 200km same as the nismo shifter same reason I have got sequential g/box.
prices for both is $700
pm me or ring 0433277823
Thanks
Hi fellas,
Thanks
Hi fellas,
hks twin power $550 firm...
nismo short shifter $150 firm....
Thanks
Hi fellas,
Thanks
Hi fellas,
Thanks
Hi fellas,
short shifter sold......
Hks module still available....
Thanks
Hi fellas,
Thanks
Hi fellas,
hks module still for sale... !!!!!!
Thanks
Hi fellas,
Thanks
Hey mate,
Yes it is still available
but firm on price for $550
I'd like to take the twin power DLI. As long as the harness is in good condition and all the paperwork is available so I can install it. I'm located in Canada. Payment by Paypal ready to go. Cash in $AUS. PM if you're interesed. Shipping to T9K 0A4.
Edited by NismoSTune
Hey buddy thanks for the interest, but I would really prefer pick up only.
Also I don't have the paperwork for the hks module, but I can tell you now that its in perfect condition also the harness too ( made for gtr r32 only harness )
Thanks
Thanks
Sounds good. If you can't sell it pickup, send me a PM. Cash in hand.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
