Hi all,
I'm starting to mod my 34, but I'm not sure where to start first.
I've got around $2k to start, and I'm thinking of either getting:
CES Racing twin dump pipe and full 3" system (40+ ATW kw gain I was told)
or
Trust PEII Cat back exhaust, intercooler and a HKS FCD.
Any advise would be great, thanks.
K
https://www.sau.com.au/forums/topic/275753-mods-for-a-34-gtt/
My opinion, others will see different:
I would start with the exhaust as it is one of the first important mods which will pave the way for future upgrades. Focus on the supporting mods before going too hard on the engine.
After this, opening up the intake with a performance panel filter or pod setup would be second.
Have a read of the Quick Ref Guide
http://www.skylinesaustralia.com/forums/Fo...ick-t66556.html
Was made to help new users :)
In particular - this thread
http://www.skylinesaustralia.com/forums/fi...-co-t45218.html
Its all about "what mods to do first".
cheers
Was made to help new users :P
cheers
Thanks for sending the link, much appreciated.
40+ KW at the wheels with an exhaust!!!!! Not for shit! :P
MAYBE an extra 15 - 20 rwkw.
Step 1- Straight through exhaust with dump pipe (Should be around the $1,300 mark for a good custom setup)
Step 2 - Pod filter (Should be about $60 with the flange which you can purchase from repco)
Step 3 - Front Mount Intercooler (about $900 for a decent one installed)
Step 4 - Manual boost controller (turbo tech) wind it up to about 10-11 PSI (At this stage, your car should not be running too rich or retarded) $30
At this stage you should have about 170 - 180 rwkw (About $2,300).
If you choose to get a power FC (which is over your budget) would be a wise move, should get you to a bit over 200 rwkw.
Also, don't forget to put a coke can in between you BOV and piping to give you the extra 120 rwkw of compression surge.
40+ KW at the wheels with an exhaust!!!!! Not for shit! :down:
should be able to get a decent turbo back exhaust for under $1000 that will do the job nicely.
just jap stainless bell mouth dump/ front pipe: $199
x-force or catco 3" cat: $175
and you should be able to get a x-froce mild steel cat back for about $600 or less.
or i just found this. turbo back exhaust for $800 http://www.tweakit.net/shop/product_info.p...roducts_id=2283
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
