Hi all,
I've got some bits n pieces up for grabs as I'm selling my 33.
1, 3" Kakimoto R cat-back exhaust for ECR33 - mid muffler section is crushed but shouldn't affect the flow of exhaust.
Asking $250.
2, 3" Bellmouth dump and front pipe with hi-flow cat.
Asking $250.
I could sell both together for $450.
3, Whiteline 24mm blade adjustable (4 adjustment points) swaybar for ECR33 front comes with bushes.
Asking $150.
4, GAB front struts and KYB rear struts - need assembly no leaks or knocks will lower the R33 by 30-40mm (estimate).
Asking $150.
All parts are located in SE Suburbs of Melbourne and I wouldn't bother post these items so pick up only for all of them.
I can be contacted by PM on this forum.
https://www.sau.com.au/forums/topic/275877-r33-bits-for-sale/
Basti,
The swaybar isn't off group buy I bought it off forum member a while ago, never got around to install it. What you see on the picture is what you get.
I asked my friend (he has done it before) he said it does bolt up to stock mounts however you could get swaybar links if you desire.
Cheers
Grant
Hi all,
Price drop!
Kakimoto zorst - $200
Dump/front pipe with cat - $200
Swaybar - $100
GAB/KYB suspension - $100
Cheers
Grant
Sorry, I don't have paypal account and not keen on post any of them cos too much headache (finding boxes for them, going to post office to get quotes etc.
Cheers
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
