Hey guys, I have a series 2 stagea neo engine of course, and recently i have noticed the engine light comes on and the car immediately starts running rough, usually on idle at the lights or something, i worked out that giving it the "boot" irons out the problem short term, meaning the roughness goes away, but maybe in a day or 2 it comes back. i have changed the O2 censor recently, so its not that.
I have done a couple of mods, and it never happend before them. 3" front pipe and cat removal, and pod filter. i cant imgine that these mods would have caused the problem, but any suggestions are welcome.
where could i take it to get the fault codes checked?
regards,
Rick
https://www.sau.com.au/forums/topic/275997-engine-light-coming-on-in-s2-stagea/
engine light and rough running, i'd say it could be your coilpacks on the way out, its a common fault. best way to tell would be as you said, take it to someone to get the error codes read. even though the engine check light has gone out the error code stays in the fault code list, so you can look it up.
you could take it to nissan, or any good mechanic shop should have a Carman or similar to read the fault code, just ring a few mechanics and ask if they can read nissan fault codes. another option is see if one of the guys on here with consult software lives near you and can help you out.
check your fault codes
i have just bought a consult port and software which arrived today to resolve all current and future CEL issues
Hopefully its woth the venture
replacing parts at random is a bit of a hit and miss affair
Edited by 910trx
Fault codes are on this site somewhere - a search should find them after a bit! Coils usually only break down under load so i would clean the AAC valve (tutorial in the skyline DIY) and/or check your plugs first (replace with coppers gapped to .8mm).
ok guys, sourced the problem, i took it to nissan and got the fault codes checked. it is the coil packs.. cheers for your suggestions.
now for the next question.. does anyone know of or have a set for sale?
as Chris has said, just get a set of Splitfire coil packs, they have been proven to be good and reliable. you can pick them up for around the $600 mark. maybe cheaper if you shop around. shoot over to the for sale section in these forums and have a look at a few of the site registered sellers, one of them might have a SAU special going for them.
Interesting, my stag does the same thing. Only happens on start up, sounds like it runs on 5 cylinders and the engine light comes on. I turn the car off and start it again and it fixes the problem. Might have to take it to a Nissan dealer and see if its the same thing. I did the spark plugs last weekend and the coil packs look perfect not 1 single crack on them :)
I had this exact problem only a couple of weeks ago i had full service done plugs and oil and the rest checked the fault codes as suggested in this thread and indeed it was coilpacks picked up a set off jjr for $400 and problem solved so much smoother im very happy with them.
i checked my fault codes and number 21 came up, nissan said it was coil packs, so i bought a set of used r34 turbo ones, reset the codes and put them im. but the engine light still comes on, what is fault code 21? and the guy i bought the coil packs off said they were good as gold, what else could it be???
fault code 21 is the ignition system, coilpacks are the usual suspects. ignition system problems can also include, and CAS, the wiring out to the coilpacks, or the PT's in the ecu itself.
firstly, change the coilpacks for a new set of Splitfires, it will remove any suspicion that its a coil failure. even though the guy you bought them off said they were all good, they are still second hand ones. you've got to remember that second hand ones are still around the same age as yours, and they seem to have failed. best thing when you are dealing with coil packs is to get new ones.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
