Hey i just got my exhaust manifold and dmp pipe sandblasted for $25 and danm they look shit hot compared to the rusty things i dropped off to them. Now the exhaust manifold still had the 4 studs for the turbo in it and they got sandblasted as well, so should i get 4 new studs for it now because the coating is taken off the studs and they will more than likely rust up ?
and also will the flanges need to be machined because the sandblasting leaves the the flanges with a matt finish compared to the shiny machined finish.. the surface looks like a sheet of 1500 - 2000 grit wet and dry so its still very smooth ..
https://www.sau.com.au/forums/topic/27610-sandblasting/
Is this the same as extrusion honing ? (sand blasting the inside of the manifold)
I've been thinking of doing this to my std exhaust manifold since it is off the car - and if it is chaep to get done (ie don't want to spend too much on something that may be being replaced something down the track)
Might help with flow ??
Sand blasting then powder coating the outside might be an option too - but only if economically viable - for the gain. Which I suspect it wouldn't be.
So I prolly won't do it.
OK, I'll shut up now.
https://www.sau.com.au/forums/topic/27610-sandblasting/#findComment-580110
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
