Hey guys how are ya's. I recently went in my mates s13, The Geforce felt really strong to mine. Why is this? Like the power was unbelivable.. compared to my 230kws RB25DET in my R33.... is this because its a heavier car? and lighter car?
Just wanted to know your opinois boys...
https://www.sau.com.au/forums/topic/276212-rb25det-230kws-vs-sr20-190kws/
Has a lot to do with how the power is delivered. The SR20 provides more of a turbocharged 'hit', whereas the RB25 is a lot smoother and more progressive in it's power delivery.
Weight has a bit to do with it also, as does whichever dyno each car was run on so don't take the figures as gospel unless they were both run on the same dyno, on the same day one after the other.
There could be many reasons why the "Geforce felt really strong". When you’re the passenger everything feels different or were you driving the S13?
Big pot 4 cyc, light weight, always going to 'feel' snappier.
Also depends on what turbo each car has and so on.
a ball bearing turbo usually feels more progressive, where a bush it 'all in at once' from my various turbos over the years
as said about are you the driver or the passenger in the S13? as when ever a mate drive my car it feels 10 times quicker than when i drive it and visa vera with there cars.. just a wierd thing that happens i think
Well you know how fast your car is, and you know when you are expecting to give it a hit, your mate might just give it a quick boost before you relise!
anyhoo,
after driving my old r33 with 254rwkw (gtrs turbo)- with truck loads of torque, it felt quick, but as Ash said, not "snappy!"
I then drove s13deviats 210rwkw s13 with s15 turbo, and it came on boost hard and quick. the s13 felt quicker mainly cause of this snappyness, however top end the r33 would just keep pulling hard with no issues of struggle.
now I have around 70rwkw :) so everything else I drive seems like a rocket haha
+1 for passenger seat feeling faster.
never ever been in my passenger seat in my car.
i trusted someone enough to let them have a go with 350kw.....and i always call my mates pussies when they scream.
i can honestly say i havnt been that scared in a while lol.
Thats it! Im going to swap my front seats over then if the passenger seat is faster :banana:
Haha
If you’re driving and you put your foot down, you subconsciously brace yourself. Where as if your the passenger it just hits you all at once not being expected. Driver and passenger are two different experiences. Of course how the boost kicks in makes a huge difference as well. :thumbsup:
Too true. Quite a few times I've let mates drive my car which I'd say is slow but when I'm the passenger it's a different story. I've also been the mates cars and thought they were complete animals until driving them myself.
+1 to all of the above. Other thing to note is that the r33 would be putting down a higher % of its power down to the ground then the s15, thus making it feel more linear and progressive.
Both cars are an absolute jewel tho! :thumbsup:
i drove a s13 putting out less power than my 33 at the time and it felt a fair bit faster, however as far as times over the 1/4 went they were pretty much the same. as people said, it's all about delivery. the sr20 kicks in much harder and faster, where as the rb25 is a bit more like a NA where the power is there from very low so you don't go from having a bit of acceleration to a lot of acceleration in a hit.
back when i had my 180sx (turbo sr20), the missus SSS pulsar (natro sr20) felt (and was) a fair bit faster coming out of most slow corners in second gear. since the stock s13 turbo doesn't really get up and going until close to 4000rpm, the pulsar would just pull away until the 180 came on boost and started to catch up. pulling out of our street and flooring it up the hill, the pulsar pulled much harder below 4000rpm but as the revs got higher you would be waiting for the kick, where as the 180 felt sluggish down low but then felt much quicker up top once the boost kicked in.
Yeah Passenger seat is where it's at.
I let my mate drive my car once from my place to his joint. I backed it out of the garage and put it on the street, and turned the boost down to channel 2 on the EBC which was only 12psi. We drove sedately until the temps got up and then he asked if he could hit it. We were just coming out of a roundabout onto a wide open stretch of road (1 lane each way, but had big parking lanes on each side) and when he stomped it in 2nd I nearly lost my shit. It sorta almost took my breath away, I made him pull over straight away so I could check the boost controller and couldn't f**king believe it when it actually read 12.2psi.
Major difference in the perception of speed and accleration from driver to passenger and I can now understand why people get out of my car shaking.
  • 9 months later...
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
