Wont be going after all, somethings come up
-D
Yere same with me found out we have a early b ball game thought it was a late one this week.
Can I please have a copy of the minutes as well.
Cheers
Edited by mrRS4
Yippee, i am welcomed somewhere :P....send me a sms on 0411876139 so i have ur number and can find you guys once i get there. Off street parking, i aint paying for parking, you should know by now i am a bit of a scrouge :P
So, what happened folks? Any news?
I'll have the minutes put together sometime tomorrow (busy today ... for once) and I'll also post up a summary of what was discussed shortly thereafter.
I'll email you a copy of the minutes also Martin. :laugh:
Some really good things came out of the meeting ... and its was pleasing to see more members attending. :)
To all,
My apologies for the delay. I'm an Office Manager/Bookeeper and I've naturally been flat out with the EOFY workload ... in case you haven't noticed I haven't been on here as much :down: I now have time to scratch my ass ... and will have the minutes done today and emailed off.
I've got a meeting before lunch with the Accountants to hand over the reports, then its not my problem anymore. The office will be empty this afternoon, which means plenty of time to put my feet up and get onto finishing those minutes with ease.
Thanks for your patience.
Nene, I will be right onto your requests today ... pronto!
Ruby
:D
So ... you're giving me free IQ for the EOFY bullshit I gotta do Damo? :wub:
Noice!
Meeting minutes have been emailed. If I missed anyone, PM me your email addy.
:P
Ruby I've been meaning to join up but I will only do it on one condition - that you change your avatar. I'm sooooooooo sick of having to see a male groin thrust in my face. Use scandy's avatar as an example of what I'd prefer to see.
I wouldn't be able to attend Monday meetings as I play indoor soccer on Monday nights.
Edited by writeoff
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
