Mike,
How do i tell if these will clear the racing hearts? Also will it be direct bolt on?
Hi Chris,
How much room do you currently have between the brakes you have now and the wheel? If you have an inch you should be fine if you have less it will be a tight squeeze and may require you to use a thin spacer for clearance. As for fitment you will need to see what size bolt your calipers are held on with as I have seen Stageas with both the more common 12mm bolt size as found on 300ZX, R32 GTS-T, R33 GTS-T or it will be the 14mm bolt size as found on R34 GT-T, R33 GTR, R34GTR etc. If you have 14mm you are laughing as it will be a straight bolt on with only wheel clearance being an issue. If you have the 12mm bolt size you will have to drill out the two 12mm diameter holes you have on each front stud axel to 14mm diameter and it will fit.
If you go to R33 GTR Brakes at the front you will need to use 17" wheels if you get defected so R34 GT-T stockies would be best I have a set you get borrow with new tread if you ever need them just give me a sms or call.
Hi Chris,
nigel, i think you've been mis-informed. r33gtr is 12mm so will bolt up to r32/r33 etc no worries. it's only r34gt-t and r34gt-r that are the 14mm bolts and require modding the stub axle.
chris, they will be a direct bolt on for you mate, i can't remember how much clearance the racing harts have - just check how much room between the back of the spoke and your current caliper and let me know what it is. even if you can't fit it, we know those wheels could do with 25mm spacers anyway :whistling:
Front and rear calipers and disks? Pics?
did you even read the first post mate? lol it says front only haha
chris, they will be a direct bolt on for you mate, i can't remember how much clearance the racing harts have - just check how much room between the back of the spoke and your current caliper and let me know what it is. even if you can't fit it, we know those wheels could do with 25mm spacers anyway :)
Thanks Mike was getting confused with R34 GTR and R34 GT-T that have the 14mm bolts don't know why I thought R33 GTR were the same sorry guys.
I also have a set of front & rear Carbon fibre brakes with Strange Engineering calipers.
They are not suitable for street use though. Perfect for Drag racing as they are very light
& pull up very well from high speed.
I am in WA, only want the calipers, have rotors and too heavy to send any way.
I will pay you $800 into your account tomorrow if you are interested
Call 0417943522
regards
Mike
Edited by Mike Rowe
These brakes are SOLD pending payment. I will let you know if falls thru.
Only $80 to send lot to Perth so better to just pay $1000 + postage for the lot.
Munro I will take them if sale falls through, call me 0417943522
Mike
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
