Hey guys, I've been looking around at R34 GT-R's... which still isn't out of the picture however my cousin is a mechanic at a Sydney workshop.. I've been told by my cousin that the GT-4's are 4WD similar to the GT-R however still have the NEO Straight Six 2.5L... Now I've found a few for sale (They are quite rare) they obviously come non-turbo.. however I'm probably looking to do an engine transplant with a RB26DETT or an RB30DET.. Which will be fairly cost effective.. On tradingpost and carsales I've found a few in the 13-20k range..
I'm not looking to mimic and R34GTR or to pass a GT-4 as a GTR.. but has anyone ever considered this before? I'm thinking with the GT-R front end conversion etc.. It would look quite good and would end up costing me almost half of what a GT-R would? and the power can always be increased...
:J
https://www.sau.com.au/forums/topic/276674-importing-an-r34-gt-4/
That's a good plan but unfortunately there is one problem, for the R34's the 25GT-FOUR is not eligible for import. IT has 100kW/ton whereas to be eligible it must have 105kW/ton ormore. The RWD 25GT non turbo just makes it in, but because of the extra weight of the 4WD system it pushes it below the limit required and the 25GT-FOUR can't be imported. There MIGHT be a handful of 25GT-FOURs in Australia that were imported many years ago under the old CPA import scheme, but I would doubt it.
I see, there is a few GT-Four's in aus atm.. but they are hella rare.. I heard someone imported a GT-4 4 Door a little bit ago? thru Iron Chef Imports :s
When I was approached about bringing one in for the first time a year or two ago, I actually thought the same thing, Ben - evidently DoTaRS doesn't mind. I've brought a few in since.
http://rvcs-prodweb.dot.gov.au/sevs/030-00.htm
Yeah before I replied I double checked the SEVS list and they list it as being eligible and and the RB25DE as being 105kW/ton (so just ok), but when you do the actual math on the RB25DE in GT-FOUR guise then it's 100kW/ton and a no go. I think DOTARS own mistake in the paperwork must be letting it through... maybe we shouldn't be talking about it in case they see and decide to fix the problem :P
Yeah, I'd urge a bit of caution and I'd want to have a chat to a compliance workshop before to comitting eveyrthing, but it sounds like it might be alright.
In regards to your original idea then I don't see anything wrong with it. Keep in mind as well as just swapping the engine and putting a nice kit on it you'll probably want to upgrade the brakes since non turbo R34's had gaybo sliding caliper jobbies, the diff might not be an LSD (which you could live with but if you're going for big power you might want to change) and you might find it's much cheaper to buy an auto GT-FOUR in which case you'd need the gearbox, master cylinder and pedal box from a manual for the conversion also. If you're happy with the work involved and the expected costs I say go for it, there's no shame in owning an uber fast 4WD R34 that just happens to not be a GTR if you ask me! :P
I got one :blink: Big thanks to the chef who got it for me, as i had no idea they existed until he showed me them. I got a manual one, and to be honest, i would be saving for a GTR. Im in the middle of doing the whole gtr bit. Already got GTR Brembo's and a Getrag arriving this week and still need to get a whole BNR34 rear subframe. Then there are little things which u need to replace, like master cylinders, fuel pumps etc
In the end i'll be pushing 400+kw's out of it, but im mainly doing it cause i want something different which no one has.
I got one :P Big thanks to the chef who got it for me, as i had no idea they existed until he showed me them. I got a manual one, and to be honest, i would be saving for a GTR. Im in the middle of doing the whole gtr bit. Already got GTR Brembo's and a Getrag arriving this week and still need to get a whole BNR34 rear subframe. Then there are little things which u need to replace, like master cylinders, fuel pumps etc
That's awesome :D..
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
