Just bumping it again... Also, bear in mind that the graphics on the car are laser-cut vinyl: THEY ARE EASILY REMOVED!!!
Hurry up and buy it: I really need a daily! :(
  • Replies 44
it's bumping time again!
C'mon guys: it's cheap, it's unique, and it's a great drive!
I'm looking for swaps for a R32/R33 GTR and cash my way...
Hi, Mica
It is a pity you are in the coast. I have a collection of 7 GTR33 ranging from 215kwrw, 303kwrw(N1), Veilside Combat R detuned to 280kwrw,355kwrw (-5) to 455kw at all4 T88GK38 Pete Lopez's old gunner) a full-on track car is being built at present. You have got a lovely car for a project. Think of this, Source a VG38dett R35 from a wreck, match a strong gearbox and diff and a lot of clever engineering to make it all work. You have got a unique gunner with both show and go.As for your Stagea,get a RS260, stick a pair of Garrett-5 or T88 single for straight line speed. WoW.May be we can talk on the phone with a possible swap.I also have a 2000 S2 stagea Neo done 50000km only
cheers
Alex 0439 818008
Tim GTR
He who dies with the most toys wins!
So far, you are in the lead. I love your project idea for the V35. Someone needs to do it
Hey Micah, keen for a road trip to Victoria?
Yeah, but I want to take the Stagea!
However, if that's what it takes: I am willing and able to travel... Tim: I'll be in touch shortly... I am interested :)
Tim GTR: still waiting for pics/info on the proposed swap: I am quite interested, as per the phone conversation, but I need more info... please email me at [email protected]
Cheers,
Micah
  • 3 weeks later...
OK: No more playing around, and no further drops in price.
$36900.00
I would really like to see this gone guys: It's going to waste locked in a shed with nobody to take it for a spin!
Give yourself a nice carbon on blue Xmas present!
Ok, so I broke my back in 2 places this week, and am now (under nuerosurgeon's orders) Never again allowed to drive this car: Carbon fibre seats and stiff suspension are not spine-friendly...
So, I am now looking to either sell the car for the $36900 asking price, or will consider swaps for a late model (mostly standard) Luxury car of similar/lower mileage: I need something cushy that won't put any undue strain on my damaged spine....
I am now negotiable on price within reason, and really need to offload this car: Not being allowed to drive it at all has rendered it completely useless to me...
C'mon people: bring on the offers!
Spewing dude.
If you lived in Perth and i could see the car in person i might do a swap with you...
and sorry my car don't have Brembo and it's an auto, which would be better for you since it's such a smooth ride :)
  • 3 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
