i'm in need of some help with my r32 gtst
the steering has been heavy since i've purchased the car
firstly i put in a lock bar and removed the whole hi-cas system
then i changed the p/s pump and the steering rack
still has heavy steering
can anyone help me?
would really appreciate it if you know what the problem is
Cheers
Edited by DFAULT
https://www.sau.com.au/forums/topic/276730-heavy-steering-r32-gtst/
Did you remove all the electrics for the hicas as well? The hicas module controls the power steering assist, so if there is a problem with that, or if it isn't even there anymore, the steering will always be heavy.
If the hicas electrics are still in there and working, did you reconnect the solenoid on the steering rack when you changed it out? Does the steering start off light and then go heavy after a few minutes? Why did you change the rack and pump anyway?
Same prob happened with mine last week. HICAS has been removed for years with no problems but now steering starts off very light for approx 1 minute then goes heavy. Have not checked it out yet but if someone has experience with diagnosis then I'm all ears!
Possible stuffed solenoid on rack??
Edited by 321 GO
I left all the electrics for the hi cas
i disconnected it but it still has heavy steering
i plugged and unplugged the solenoid on the steering rack but did that nothing
i also plugged and unplugged the hicas unit in the boot but that did nothing
the steering is constantly heavy
i changed the rack and pump thinking that it would fix the problem, but i guess not
could there be a blockage in the lines?
i also get a weird noise when i move the steering wheel to a certain point, sounds like air coming out
any ideas?
any ideas?
Ha ha. I get the same noise. Thought it was just extra noise being allowed to travel up the steering column after installing an alloy steering block in place of the rubber one.
Where is heller44? Looks like he had some answers!
I've been playing in the red dust up north, no net access for monkeys up there.. only flew back in tonight.
I reckon you both have very different faults to each other, andrew yours looks to be a fault condition with the hicas unit, so you need to do a diagnostic on the hicas, look in the tutorial section for the procedure on how to do it, it is a pain to get it right but you should be ok.. count the flashes and work out what part of the system is faulting.
Dfault, yours isn't even starting out and then faulting, probably throw a multimeter on the pins for the solenoid on the rack and see if you are getting any voltage there at all. Possibly where I would start.. nice easy check anyway. Once that is done you can go from there and see wether it is mechanical or electrical.
i have this same problem in my cefiro
non hicas model
on the drivers side i still have this solenoid looking thing with 4 hoses ( i unplugged that )
then i have this senson down near the drivers wheel ( i thought could be a speed sensor that adjusts steering tension at high speeds )
and lastly i wound the nut out on the rack ( adjusting one )
done all that at same time and my steering is slightly better lol
just dont know what one made difference, its still heavy as thou !
Thanks heller44!
No HICAS globe in the dash as it was taken out when I removed the HICAS system many years ago (rack, oil lines to front etc).
Now that I think about it I'm sure my speedo stopped working at the same time. Would it be fair to say this could be my problem seeing as the steering appears to be speed sensitive? Honestly was not aware of speed sensitive steering in R32 and thought that as the R32 uses a speedo cable it would not be able to have a speed input to anything else on the car. Would be awsome if I'm wrong and my inoperative speedo could be causing my dramas!?!
*facepalm...
no speedo, no speed sensitive steering.. sheesh. mechanical cable drive from the gearbox sender to the cluster, built into the back of the speedo itself is something like a tacho generator that transmits a speed pulse to both the hicas unit and the ecu.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
