  • Replies 41
Idle speed controller ****SOLD PENDING PAYMENT**** 88CHASER
Top radiator Inlet housing (connects to injector plate) ****SOLD PENDING PAYMENT**** 88CHASER
THE REST OF THE GEAR IS STILL FOR SALE!
OFFERS WILL BE CONSIDERED,BUT NO LOW BALLERS/TIME WASTERS!!!
R33V-SPEC RB26GTR HEAD,CAMS AND CAM WHEELS ****SOLD****(OJR32) PENDING PAYMENT
OIL/WATER LINES ****SOLD**** (JAMES03)
STILL SOME GREAT PARTS REMAINING!!EG TURBOS, 4WD SUMP+GEARS, EXHAUST MANIFOLDS, HARMONIC BALANCER (32), Y CONNECTING PIPE,AAC VALVES X2, 33 FRONT BAR, 33 FRONT GRILL WITH MESH.
mAKE AN OFFER IF YOU WANT ANY OF THIS STUFF!!!
ALL PM'S REPLIED TO!
2ND OIL FILTER/COOLER ASSEMBLY ****SOLD**** (S13 SKYLINE INSIDE)
PLENUM WATER/VAC LINES ****SOLD**** (S13 SKYLINE INSIDE)
REAR MAIN SEAL, WATER INLET PIPE ****SOLD**** (S13 SKYLINE INSIDE)
NEW PRICES FOR THE REMAINING PARTS
4WD SUMP+BAFFLES $350
R33VSPEC TURBO'S (INCLUDES DUMPS,EXH MANIFOLDS ETC)$800
R32 GTR TURBO'S (ALSO INCLUDES EVERYTHING AS ABOVE) $500
STOCK FUEL RAIL + REG (X2) $50 EACH
R33 INJECTORS 440 $200
THROTTLE BODIES + LINKAGES $250
INJECTOR PLATE $300
PISTONS + RODS $100
AAC VALVE (X2) $100 EACH
R32 HARMONIC BALANCER $50
ALTERNATOR (X2) $60 EACH
IDLE SPEED CONTROLLER $80
P&H IS EXTRA AT BUYERS EXPENSE!!
IF YOU WOULD LIKE ANY OF THE REMAINING PARTS SEND ME A PM OR CALL 0400262578
CHEERS HULI
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
