the v35 are designed to have a staggered wheel setup. You can put the same tyres front and back at least 245/40/18 (i think, correct me if i'm wrong please) in order to get the closest Speedo reading. If you decided not to go to the stock spec it'll put your Speedo reading off by alot of margins.
the stock for 17" tyres on V35 is 225/50 17 and 235/50 17.
  • Replies 81
Posted Images
it's 225/45 18 and 245/45/18
I'm not sure what are you talking about being the front sitting little lower.
if you referring the 225 that's not the thickness of the tyres it's the width of the tyres. 50 is the thickness of the tyres.
hmm i have 20inch 255/35 on rear, and 225/45 on front...guess the 20inch would really through out the speedo.....
The tyre shop that fitted 225/45 on your 20s should be shot. do a search and look for a tyre calculator.
why does front and rear tire size for V35 coupe is different
For more rear end grip.
( is it stock standard)
Yes.
is it ok if I have 225/45/18 front and back ? ?
Your speedo will over-read more than it does already.
Your ABS may (but probably won't) trigger prematurely.
Your VDC may trigger prematurely.
is it for the purpose of aerodynamic that front is sitting little lower than rear?
Possibly, but probably not. The undertrays will have more of an effect on aerodynamics than the slightly raked profile.
Also, what's to say that the rest of the suspension isn't configured expecting the front tyre to have a smaller diameter than the rear, and is relatively higher on the body to compensate?
The front tyre has a slightly smaller diameter than the rear, so assuming that the rest of the suspension mounts are the same the front would arguably sit lower. However, to keep the chassis level I find it unlikely that Nissan would have done that.
Your speedo isn't that inaccurate. With your profile drop and relatively narrow width, your speedo only under-reads by 1.3% compared to stock (which over-reads a bit anyway).
f**k yeah. That width and profile is stock on an 18" rim - its way too high for a 20.
wow... what a heap to re-read and take in.
Just a couple of things that I didn't really see clearly stated;
Can everyone pls also remember the rolling diameter for one brand tyre in ANY size may differ from the same size in another brand.
The below information was posted and there was lots of good tyre calculators linked, however I just want to re-iterate it...
Tyre sizes work in this way 245/45/18 = Profile is 45% of the 245mm width/rim size is 18 inch/width is 245mm.
I always work out the specifics of the rolling diameter using the actual tyre size AND the Manufacturer Rolling Diameter info.
what if I have stock 17" stock rims on and I changed to stock 18" rims. would the speedo overread?
Your speedo will not be out just because you go to bigger rims. What you need to make sure is you have the correct profile tires when moving to bigger wheels to keep the overall diameter same/similar. Thats what the tire calculator is for. Do a search.
OMG I NEED HELP.
I just got my V35 and drvoveinto driveway. I found out the mid-bottom scrape the driveway...
it is pain everytime goin in and out.
the driveway is like a dip. has a crest in the middle and thats where the scraping occur.
can I change the size of the tires(thickness ) so that i can rise the car i little. i think i need half inch only.
what would be a good size if i do it?
current on stock 18" , tires 225/45/18 front and back
Edited by tonich
To raise your car using tyre profiles alone by 1/2 an inch is going to be a HUGE change in rolling diameter. Extra sidewall height will make handling fairly wooly. Plus the fact your car will end up looking like a 4WD. Sunraysias anyone?
Time to move house ;) .
Can you approach the crest at an angle? That will normally help a bit.
I had the same problem as I have quite a steep driveway going down to the garage from the street. I nailed two planks of wood to the driveway to give me some more clearance and problem solved . Don't know if this would work in your situation.
Edited by Easy Tiger
cant do it at an angle, the the driveway is too narrow.
I will try the planks of wood. but I have to place the wood everytime go in and out. gonna to real hassle
I am not sure about 19" stock rims with stock tires. does it increase clearance compare to stock 18". i might be able to get a set
Edited by tonich
please confirm with me on this:
i have used calculator to compare current set up 225/45/18 to new tires 245/45/18.
the diameter of wheel increased from 26 in to 26.7 inch. does it means it will increase my clearance by 0.7inch/ 1.8cm?
if so what brand of tires should i get
or can i rise the height with this coilover.
link'
thanks for help
Edited by tonich
You are stuck between a rock and a hard driveway. There is nothing much you can do to the car without altering its handling characteristics or making it look stupid. Increasing tire profile to suit is not recommended. If you are currently on lowered springs, then I guess reverting back to stock suspension is one way to do it. Other than that, you will need to find a way to modify your driveway as recommended above.
I came across a similar driveway when house hunting a few months back, neither of my V's could get into it without scraping the bottom. Needless to say I passed.
Perhaps post a pic of the said driveway as well..and also do you own or rent this place?
i own a unit and i guess i shouldn't a car this size living in a unit. i now hunting for a garage near my place....
any suggestion on increasing the height with coilover? i dont mind if it looks stupid
Yes, You can go. I have coilovers sitting too low, I found the same problem with my driveway. So I increase it by 1 inch. no problem after. LOL, do looks not as good as it used to be, but as long as it do not strape my chasis.
Cheers
Cheers
any pictures my friend? how much it cost and brand?
Sorry mate, no pic so far, I was on work.
Brand is BC racing, F 8kg R 6kg, I set it to the softest. not to much different with factory on comfort but do corner a bit better.
Price is not bad. Send me PM for details. I don't want put here as not sure whether it is proper.
Frank
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
