Good to meet some of you guys recently.
An "interesting" night.....
Good job Mona, Thanks.
Thinking of ROH Drift R. 18" for the Z. with Potenza 225/45 and 245/45. Close to deal-any thoughts?
Also the stock 18"'s on up spec Z are the same 8" width f and r, or do I go 8" front and 9" rear. Appreciate your comments.
P.S.This will release the 17" Z wheels and Potenzas (14000k)
if theres interest in them ..OK for 200, Skyyline etc I think.
Regards
Steve (Old man..duuuh)
https://www.sau.com.au/forums/topic/27723-galstongreat-to-meet-youmy-wheels/
Steve,
Thanks for coming along :) was good to see a 350Z on the road with us
Mate the Drift R's sound like a good option in 18x9 and 18x8 :(
Rather than selling the Stock 17's, how about keeping them and putting semi-slicks on them for track days???
Hope that helps,
Tosh
Ta for reply Tosh...
I just don't quite understand the difference in having same size f and r - or bigger on rear.....maybe under/oversteer affected?
Z Touring (stock 17") has 1/2" diff. (7.5 and 8.0)....up spec track @18"..no difference......
BTW. Sat Nav and dvd going in too.....
Steve
Nice meetin u Steve, i was the one borrowing ure lighter lol.
I've been tryin to do some research at work (car park attendant) checkin out all the cars rubber.
Porsche turbo use 18x8 an 18x11! Thats 225 front and 295 rear! But then again thats rear engine.
BMW M3 Uses 18x8 18x9, 225's and Stretched 255's
Most performance rear wheel drive seem to be usin 225 front and 255+ rears. Definetly go 8 front and 9 rear. Taking into account that 255's on an 8" would be pushing it and u'd have a bulge in the tyre wall.
Cheers,
Lozz
Well, there is a bonus to same sized tyres front and rear, you can rotate them if the wear isn't even front to back.
You only need to go bigger tyres at one end if you're not happy with the traction or balance. If you're not having wheelspin trouble or oversteer out of corners you probably don't need new tyres.
Thanks fo replies guys
The stock tyres are different f and r, on both 350Z's, which precludes tyre rotation anyway...
The 18" Track is 225/45 and 245/45
The 17" Touring is 225/50 and 235/50..
Makes it hard..I'm thinking now 8" 245/45 front and 9"265/40 rear which keeps it in spec.
The width is more cosmetic to fill the guards than anything else!
Cheers Steve
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
