The guys at The Toy Sop imports in Newcastle have helped me out when I've needed parts quickly, as have Z Racing (or maybe Zed racing...) in Adelaide. Good reasonable prices with them too.
They might be able to help you out.
  • 4 weeks later...
My car is fixed by small workshop in Hume. I am impressed by the way they trated me and my car.
HUME BODY WORKS is the shop that saved me time, money and stress. If anyone need small touch-up or ground restoration (I have seen a few in the shop) call Geoff and make an appointment. I know you will not be dissapointed.
  • 1 month later...
Thought it might be worth adding a reply even though your car was fixed, just to give feedback on another repairer in Canberra incase anyone goes seraching.
Recently had my gf's Celica repaired at a place called Hall Brothers in Fyshwick. Fixed some front quarter damage and a scratch on the bonnet caused by a Kangaroo KO'ing itself on the side of her car. Whilst it was there they also touched up her wing. It was insurance work (save the wing) but it came out really nice. She has one of those metallic blue colours which are apparently hard to match but you couldn't tell it's been repaired.
I was so impressed with their work i took my 260Z to them, which had damage to the rear quarter (clipped a tree avoiding a 'roo :bunny: decided to fix it out of my pocket rather than claim through insurance) they did a fantastic job and i would definately recommend them.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
