I've got my exhaust system all sorted out except for the cannon. I've got HPC coated extractors from DKNE, and getting a custom 2.5" system made up, although unsure if I should go with a 2.5" or 3" cannon? What would be the difference in sound and what have you guys got?
https://www.sau.com.au/forums/topic/277324-25-or-3-cannon/
Are you talking about the actual canon tip 2.5" or 3" or the whole exhaust system? If the whole exhaust system go with 2.5" for best all round gain. 3" catback will give you more top end, more noise, and less bottom end.
https://www.sau.com.au/forums/topic/277324-25-or-3-cannon/#findComment-4693992
Cannon Muffler size you can have up to 4.5" or what ever size you want (Out Pipe) but the In Pipe must still say the same 2.5".
Yes, I know, everything has been answered except my question - out of a 2.5" or 3" cannon what would be better?
https://www.sau.com.au/forums/topic/277324-25-or-3-cannon/#findComment-4694220
Stick to 2.5".
2.5" straight through all the way.
Cuz your car is N/A, nothing over 2.5" other wise you lose back pressure (There is the correct name for "back pressure" but I can't remember...)
This is only for straight bolt on.
You can have a larger size pipe if you want but will requirer tuning.
https://www.sau.com.au/forums/topic/277324-25-or-3-cannon/#findComment-4694241
Stick to 2.5".
Volumetric efficiency.
Think of it as drinking with a thicker straw vs a thinner straw. Thicker straw takes more effort to get the drink (less low down torque), but once it starts flowing you can get more drink (top end power). With a thinner straw little effort is needed to get the drink flowing (more responsive low down torque) but the flow reaches its peak quickly (limited top end power). The volumetric efficiency refers to time it takes for the volume of the straw to fill with liquid. In real world terms with a car, this higher top end power sacrifices response and low end power which for day to day driving is generally better.
To take that analogy to another level, if you were entering a drinking competition and you had to choose a straw, which would you pick? The larger straw as once you fill the straw with liquid, the liquid will flow a greater amount. Likewise, if you're car is going to see the track more often, or higher revs more often, then a larger exhaust pipe diameter would be ideal as the top end power outweighs the need for bottom end power and torque.
https://www.sau.com.au/forums/topic/277324-25-or-3-cannon/#findComment-4694502
Stick to 2.5".
Sorry to disapoint, but backpressure is never your friend - this logic is so 1930's
I agree that a large system may cause you car to run poorly down low, but this is a tuning issue rateher than a volumetric issue.
On an NA, the science is to get all of the harmoniocs of the exhaust right. When correct and you can scavenge extra exhaust gasses out (due to a low pressure region forming at in the exhaust near the open valve) and hence draw in more clean air/fuel mix. (mor clean mix in means more bang)
It was this technology that made Yamaha so succesful with their bikes after WW2. This was the result of a merger between a german motorbike firm (that shot through after the war) and Yamaha (who specialised in musical instruments and hence harmonics.) They succesfully cracked the technology.
This is also where terms like "tuned length headers" comes from.
For another example, consider drag cars, they have large, short exhausts to minimise back pressure. Whist I agree they run much of the time at close to full throttle, they still cant afford to have a sluggish bottom end as the race is over too quickly for any part of the engine not to pull its own weight (if you will excuse the punn)
So, to answer your original question, the cannon is only for asthetics, so it wont matter what you put on so long as it wont restrict the rest of the system. I would go for a nice 3" (again asthetics) but you may want to have them tack it first so you can give it a short drive and see if you like the sound (differens 3" cannons will sound different and be quieter or louder depending upon the internals,) so just because 1 is too loud, wont neceseraly mean they all will be.
https://www.sau.com.au/forums/topic/277324-25-or-3-cannon/#findComment-4694919
Ah yeah... "Volumetric Efficiency"... That's it.
The straw analogy puts it in simple terms and very understandable.
I see...
So basically if your N/A car sees a lot of track of track days with plenty of full throttle, still a larger diametre exhaust will well a lot at top end, but keeping in mine not to sacrifice low down.
So in Jack- 's case if it is just for street / daily 3" still ok?
Thanks for that info fellas!
https://www.sau.com.au/forums/topic/277324-25-or-3-cannon/#findComment-4695018
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
