Ive just bought a Pioneer 600 w amp second hand, two new kicker 6 inch splits and two new blauplunkt 6 inch splits for the rear, one second hand JL audio sub, and ive got a JVC mp3 head unit. Can anyone give me some ideas on weather to run all 4 speakers to the amp or to run the 2 front speakers and the sub ?. Also does anyone know where i could get a general install map (diagram) with wires flowing to each component ?
Thanks for your help !
MATT
https://www.sau.com.au/forums/topic/27733-need-install-help/
do u know the specs of the amp in rms and the specs of ur subs and other speakers?
generally u'd want to run the amp to the front 2 speakers and bridge 2 channels to the subs but normally u'd have a seperate amp for the sub as it requires more power than speakers.
https://www.sau.com.au/forums/topic/27733-need-install-help/#findComment-579851
If you are on a budget, run the fronts of channel say 1 & 2 of the amp. Bridge up channels 3 & 4 by using the outside 2 terminals on the and low pass them. Runn the rears of the jvc headunit, will be all they need. later on, run the rears off that amp as well and go to someting like a mono block for the subs. hope this helps.
Any further questions just shout out
JR
https://www.sau.com.au/forums/topic/27733-need-install-help/#findComment-580019
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
