  • Replies 477
Not sure what turbos the Hi Octane 34 runs but im pretty sure it runs a AWD RB30
yeah its an rb30: http://hioctaneracing.com.au/news_RB30.html
your signature is a crack up & i bet some people really believe this as well HAHA
  • 5 months later...
quick update guys - i decided to upgrade my n1 oil pump to the nitto oil pump as it wasn't up for the task.
greg @ proengines also made a custom collar to better suit the oil pump.
i'll be taking the gtr to crd hopefully this sat for a quick health check :happy:
hi guys,
just did a road test in a back street & recorded the results on my blitz ebc (rob @ rips got me thinking on this):
3rd gear: 1bar boost @ 3800rpm
4th gear: 1bar boost @ 3500rpm
5th gear: didn't have the room but would 'guesstimate' 1bar boost @ 3200rpm
mr rob ward, your t04z setup which makes 1bar boost @ 3000rpm, what gear is this done in?
i should also note that my setup has been tuned for top end power, im sure if i asked jim @ crd to tune for mid range my revs would come down even lower @ 1bar boost...
regards,
marko
i dont think you could beat the stock extrude honed manifolds...especially if they are black coated.
Yo dirty man, do you think it's worth the extra money for a set of aftermarket low mount manifolds- compared to a set of honed and ported N1 manifolds?
I'd like to keep the N1's (I have them all done allready) but if there are reasonable gains to be had I'll ditch them... I don't want the ex-mani's to be the restriction.
I know you were running aftermarket manifolds with the GT-RS's.
2.8, head, cams, greddy plenum and 50mm tb's, GT-RS's....
Cheers
Justin
There needs to be a 2.8 section...
i think i can answer on pauls behalf as ive had this coversation with him in the past...stock manifolds are much more reliable & just as good if not better than aftermarket items.
mark with his hi octane gtr was using tomei manifolds then went back to stock ones which were matched & honed for better response, as per his interview on ignition dvd
Thanks marko.
Yeah, I'm really trying to stick with cast manifolds. I'd hate to have to change manifolds after a few thousand km's because one cracked... unfun job.
I've run 400rwkw with stock-stock manifolds in the past... un ported, honed or coated.
I seem to ask Paulie alot of qn's because he's run good numbers with GT-RS's... I'll be running GT-RS's on the new stroker motor.
Anywho... thanks for the reply.
Cheers
Justin
Cheers
Justin
No...spend it somewhere else
  • 1 month later...
hi guys,
i have ordered a new set of splitfire coilpacks as my factory coilpacks started to misfire. tell tale sign was that 1 of plugs was very dark (thanks for the guidancec paul).
whilst im doing this i looked at my plugs...i am currently running ngk pfr7a (1.1 gap) & have done 1000km with them. should i just clean them (with petrol & toothbrush) or should i replace them as they did clean up well.
my tuner recommended i go with pfr7b platinum if i update them - the problem is that nobody in sydney stocks 7b's let alone 7a's! this is head fark & a 1/2 :D why is it sooo hard to buy a set of plugs???
hi guys,
bcpr7es marko...made better spark and more power with these puppies than any platinum plug you care to name. I run coppers in the race car too...but not 7's.
invest in other mods such as alcohol
Baah... Alcohol is for drinking
Gasoline is for washing parts and
Nitro is for racing!!! ha ha ha
Yeah, I was thinking about methanol a while ago, but it really dosn't go with my street car build. Also E85 isn't available in Tas, so I stuck with the ID1000's instead of the ID2000's...
Oki doki paul. Better spending $20 on a set rather than $150, its a win win solution
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
