  • Replies 147
Posted Images
There's no stock standard R35 (which I'm kinda cut about) but there are 5 JGTC R35s in there to choose from.
I went through my affordable car list before (that's a nifty feature! Lists every car from worst to bad that you can afford!) and some were locked out, so I'll be doing the DLC stuff tonight me thinks...
Apparently its something to do with a deal done between Nissan and Polypohny Digital (the developers of the Gran Turismo series). Polyphony helped them develop the user interface and did some of the programming for the new GTR, so there keeping the GTR out of the hands of their arch enemy Microsoft and there direct competitor the Forza series.
https://www.sau.com.au/forums/topic/277410-forza-3/page/7/#findComment-4905079
You won't regret buying a wheel :P I actually don't know what Forza 3 is like with the game controller, but I had the same thing when playing Forza 2.. you reach a point where you really need the wheel and pedals.
https://www.sau.com.au/forums/topic/277410-forza-3/page/7/#findComment-4914378
Ok, picked this up a few weekends ago and have to say I'm hooked! I love that driving from the inside of the car is so intuitive as good as outside the car.
So, who plays it online? Can you set up your own races for others to join?
I haven't upgraded to Gold Live but may be worth it for this.
https://www.sau.com.au/forums/topic/277410-forza-3/page/7/#findComment-4914809
awesome game... dont bother dragging in anything other then a Datsun 500 if the person your racing has a Datsun 500 because you will get owned.
go to the eventlist and access the drag races from there or setup a custom online game and do it from there, if you want to practice, just set it up as private and dont invite anyone, likewise for dori.
i think the best part is making huge amounts of money from selling cars. ive sold so many pos sprinters which i have used a design template i made with snow camo for 150k+ after only spending about 30k on it. Online auctions and fanboys rock.
definately filling the void until GT5 comes along... and i will definately be buying a good wheel setup and invest some time in a racing cockpit for them both.
if anyone wants to add me online, feel free, the gamertag is inark funnily enough
https://www.sau.com.au/forums/topic/277410-forza-3/page/7/#findComment-4915630
all the top drift scores ive seen have been that setup... i seriously cant drift with the controller... im not even going to attempt setting a score without getting a G25 or 27 first
My Datsun 510 has over 700kw :laugh:
Best i can get out of it though is a 9.8 1/4
I need to learn to tune cars properly cause i know you can squeeze an 8 out of it
https://www.sau.com.au/forums/topic/277410-forza-3/page/7/#findComment-4920001
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
