Hi all, priorities have recently all changed. Recent house purchase and now a little one one the way, means i have to turn a lot of my toys back into coin. This stuff has taken me many years to acquire and items are in excellent condition. No Lowballing please. I will not reply to these. Please PM me if you are interested. There will be a few bits and pieces to be added later, but here is the bulk of it. Parts are in Gold coast and brisbane. Small items can be sent post or picked up. Larger items we can discuss. but all freight to be paid by buyer.
ELECTRICAL
Splitfire Coilpacks Suit RB26 - Used for 3 month $450
Defi gauges - White face (COMPLETE MATCHING SET) 4.5" tacho $350
60mm Water temp $230
60mm oil temp $230
60mm fuel pressure $230
60mm oil pressure $230
60mm boost $200
All with stands, wiring, sensors and control box $1350 for the lot or will seperate.
2 x Nissan AFM's, RB series with green label comes with HKS air filter (green filters) $250 for the pair
FUEL INJECTORS
SARD 1000cc Top Feed Injectors, cleaned and flow tested. These will flow 1200cc at 60psi of fuel pressure!! $800 (brand new these are $280 per injector!)
Apexi 600cc Top Feed Injectors, cleaned and flow tested. $600
TURBOS/MANIFOLDS/WASTEGATES
T04Z Turbo kit includes Garrett T04Z turbo (0.82 split pulse rear V-Band) Turbo comes with feed line and drain. $1500
6Boost high mount split pulse Manifold $700
ENGINES
FORGED RB30/26 4WD!!
RB30 Block – extensively prepped, drilled to suit bigger head studs, bearing caps grooved etc
RB30 Crank
King Bearings – brand new
Spool Rods
CP Pistons with brand new rings
ARP main Stud
Custom RB26 sump adaptor plate with CHROME MOLY main caps
ARP Head Studs RB26 size, block is drilled and tapped to suit
Tomei Metal Head Gasket
Tomei Oil Pump & Collar
R32 GTR Head
Extensive Porting
270/270 10.8mm Lift Tomei Profile camshafts
+1mm Stainless one piece valves on Inlet & Exhaust
BC Valve Springs and Titanium Retainer kit
Painted RB26 Covers with -12 weld-ons
Gates Timing Belt
N1 water pump
Rb26 Sump (larger one can be supplied if needed)
All machining and assembly complete
$13000
STANDARD RB26DETT ENGINE - Comes with the following parts
complete inlet side including plenum, TB's, fuel rail & inj's
Complete set of covers
Cam angle sensor
turbos, manifolds, std dumps
standard flywheel
coilpacks and coilpack loom
$2900
DRIVETRAIN
PPG Straight cut gearset (1st-5th), fully rebuilt and reconditioned with new dog gears, PPG billet selectors, upgraded input shaft (Hollinger Spline). Comes complete with NPC twin plate clutch to suit, bearing carrier and everything required for it to be complete bolt in item. $8500
INTAKE
Hypertune 90mm Plenum and Hypertune Throttle Body $2500
COOLING
GREDDY Alloy Radiator R32 GTR $950
MISC
Safety 21 (pretty sure that is the brand) R32 GTR Half Cage (bolt in) with bolt in side intrusion bars. Bars are 40mm diameter. $750 comes complete with all plates and bolts.
Large Oil Cooler -10 fittings $150
WHEELS AND TYRES
Starcorp Wheels 18x9.5 & 18x8.5" rims only $800
R33 GTR Wheels rims only $900
Koya Racetech 18x9" Wheels (4 X) Black centre, polished lip Fitted with brand new 265/35R18 Federal 595 SS tyres $1000
Koya Racetech 18x8" Wheels (2 X) Black centre, polished lip Fitted with brand new 235/40R18 Federal 595 SS tyres $500
Edited by GTRHOLIC
  • Replies 43
ELECTRICAL
60mm oil temp $230
60mm boost $200
FUEL INJECTORS
ENGINES
RB30 Crank
Spool Rods
ARP main Stud
R32 GTR Head
Extensive Porting
Gates Timing Belt
N1 water pump
$13000
Cam angle sensor
standard flywheel
$2900
DRIVETRAIN
INTAKE
COOLING
MISC
WHEELS AND TYRES
standard engine sold.
can you pls post pics of Starcorp Wheels and will you post to vic at my cost?
will have photos soon. sending down to vic will be approx 130. unless you can organise your own courier.
cheers
Edited by GTRHOLIC
ELECTRICAL
60mm oil temp $230
60mm boost $200
FUEL INJECTORS
ENGINES
RB30 Crank
Spool Rods
ARP main Stud
R32 GTR Head
Extensive Porting
Gates Timing Belt
N1 water pump
$13000
Cam angle sensor
standard flywheel
$2900
DRIVETRAIN
INTAKE
COOLING
MISC
WHEELS AND TYRES
updated list, r33 gtr wheels have been sold. Splitfires and apexi injectors have been sold.
Edited by GTRHOLIC
Hi GTRHolic,
I am interested in your R33 Rims and the Greedy R32 Radiator. Are they still available?
Also where are they located so I can enquire about courier costs?
Edited by StarkReality
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
