Hi looking into purchasing a vented bonnet for my skyline, but not sure with legalites etc...
I have found this website http://www.blitsbodykits.com.au/nissan.htm which has the bonnets which are apparently ADR approved (Australian Design Rules?)
And don't need bonnet pins, which is basically what i want. I want something the cops can't pin me for; is painted the same colour as my car and don't have bonnet pins hanging out of it.
Has anyone dealt with this company or know of any other companies that suit the criteria above? better price etc?
Cheers
https://www.sau.com.au/forums/topic/277680-r33-fibreglass-bonnet/
There is no such thing as an aftermarket fibreglass/carbon fibre bonnet that meeds ADR as, stated above, would need to be crash tested.
Although Blits are a competitor of ours, we wish to inform people. Blits provide a letter to their customers in which states they comply with Queensland Transport Regulations. It is still up to the authorities to determine if the particular part meets the requirements.
If you don't want bonnet pins, but want to ensure bonnet security, I would look at Aero Catches.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
