hello,
I have an R32 gtst series 2 black in colour and I am selling these parts located in melbourne i will post pics tomorrow evening all parts are in great condition any questions please ask thanks...
R32 GTR fibre-glass front bar primed in black missing bottom lip ready for paint $100 O.N.O
R32 gtst type-m side skirts $160 - O.N.O for pair
R32 gtst series 2 front guards left or right $125 each
R32 gtst type - m rear pods $90
R32 gtst rear spolier with brake light $70 O.N.O
R32 GTR N1 headlights $250 for pair
17" Work Equiped racing wheels white 5 spoke with crome dish tyres have 95% tread one wheel does have slight camber wear $500 O.N.O
pick up is preferred Oakliegh area. thanks for reading
https://www.sau.com.au/forums/topic/277874-r32-gtst-1993-parts-melbourne/
  • 3 weeks later...
Hey guy's
been trying to reply but because i dont have enough post on here i am not able to send a pm to those who have sent me pm's really dumb i know but i dont set the rules so sami if your still interested in these rims please reply to me here and give me an email address or some thing please....
thanks guys
sorry guys just need 2 more post then i can reply to personal messages.....
im at work right now so when i finish i will reply to everyone that left me an email address...
once again thanks guys
headlights are sold
front guards sold
rear pods sold
fibre glass front missing bottom lips is pending payment
not sure wat the offset is for the wheels just know they came off my mates 32 when he imported his car and there on mine now been flat out working 7 days for the past 3 weeks but i promise to post pics this weekend...
  • 3 weeks later...
Hi everyone sorry for the later reply been busy with work....
i have pretty much sold everything now but the rims 17" work equipped wheels white 5 spoke with chrome dish probs close to an inch in-depth with tread will post some pics just been flat out latley... and getting isck of not being able to reply to my pm's really stupid thing that! Might have some 5 spoke 18s if anyone is interested some gutter rash no tread on rears make an offer... also i have a quad i am looking at selling 200cc 4 speed and reverse headlights, horn, adjustable rear suspension, remote start alarm once agian will get some pics
really sorry not able to load my pics and still not able to reply to my pm's please email me at [email protected]
thanks
And in reply to the pm i got the other day yes the wheels are 5 stud thanks...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
