It's not a pretty sight in there is it! Rather shocking to be honest. Concerning the cleaning of the final runners before the valves, I got in there with a wet and dry vacuum while I was scraping, removing the plugs is a good idea whilst doing this too.
Does anyone know if any workshops in Auckland can do this kind of thing without it costing an arm and a leg? And who could do it without breaking or ruining anything? Would like to get mine done but I think this is a bit beyond my basic DIY skills...
I would print off the photos in this thread and take the car into a good firm like city nissan Takapuna. I would also tell them that unskilled home mechanics can complete the job in 4-5 hours with coffee / beer breaks, so if you get a labor bill with 10 hours on it then you can tell them where to stick it. This should minimize your chances of getting shafted.
Edited by chad bob
Ok, guys here goes.
Got in there with a lot of brakeclean, rags wrapped around screw driver and a good compressor. Took a very long time to get most of it out, I did my best. Then cleaned the plenums, the lowest end block and throttle body. I did the cylinder head chambers first so when I cleaned the other parts, it could dry out good. I used a hack lot of compressed air to get the shit out plus any vapours.
Fitted all together, biting my lips all along. The exhaust flange bolts are officially the most *%$#*@ed of the lot and you need Jap. finger to reach and align them. I did not block the flange as my GF will have the fits if and when an engine light starts flicking.
Ok, time to start. Left the air filter out and sprayed a tiny bit of engine start in it. Did the throttle position learning as well before starting just to ensure all is done right the first time. Took me 2.5hrs to get all off and about 4 hours to get it all together. 40 mins of the 4 hours was spent on one exhaust bolt - *%&$# piece of %^#&*
She started in the first pop and hummed away. I was very pleased and let out a sigh of relief. Have driven it for 50kms now and all is running smooth. Made a heck lot of difference in pickup and go and catches up quite quickly on the top end.
All in all, I am happy. Thanks to info in this thread by you helpful lot. Cheers guys.
(PS - sorry no pics as the family camera was not in working order)
Well done X-Mod! Hopefully this is a job that really only needs doing once, then just a follow up with the Subaru upper engine cleaner every 10k or so will be enough to keep it clean. This is not a job I want to be doing regularly!
After my exploration I beleive that once all intake components have been cleaned and the EGR has been blocked and the secondary cam cover breather is re-routed, then the buildup will not return. I too would not be looking forward to stripping again which is why I decided to do everything I could while I was in there..
Edited by chad bob
I wonder if one of the accessory catch can systems available on Ebay for the G35/300Z/350Z like the one below would be one way to deal with the breather problem Chad_Bob?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...e=STRK:MEWAX:IT
Edited by Spong
Hey that's a nice bit of kit. Site glass as well...very flash! Looks like the answer to me.
Damn you Dave, something else I want to get now :( .
Most deffinitely, they work well, I have one of those on my trackdayer, you don't need a specific Nissan unit though, the generic ones work just as well from BNT/Supercheap/repco. I didn't grab one for the stag as I didn't want a foreign object sitting under the bonnet, like some shiny thing that'll raise questions (and eyebrows).
I pulled off the brether hose that enters the intake piping just afdter the AFM and just before the throttle and it looks dry, this means that the oil vapour is condensing in the pipe and running back into the cam cover (this is what we want to see), so I connected the second bank's breather into this pipe and it seems to be working wonders.
Edited by chad bob
Hey guys, going to tackle this all at once in a few weeks, hopefully sort out a lot of niggles with car. Can those of you that installed catch can please let me know what size fitting you used, the choices I have are 9mm and 15mm.
Cheers
  • 1 month later...
Hi, hopefully some of the earlier contributors are still monitoring this thread as i'm interested to hear about any updates re the intake cleaning and results.
I read the thread with great interest as i bought a 2004 M35 250RS 12 months ago. I've been quite happy with it but noticed the occasional light surging when under a trialing throttle or going up a steep hill. I changed the spark plugs around Xmas 09 and was horrified at the state of the old plugs. They may well be the original plugs...the car's done 134000 now. Anyway, i expected to see a marked improvement in performance and economy given the state of the old plugs but i can't honestly say it drives any better. The fuel economy hasn't improved at all which really surprised me. I did notice at the time the build up of soot on the inside of the butterfly valve. This thread goes a long way to explaining why it's there.
So last week i bought some Subaru upper cylinder cleaner and followed the procedure expecting to see massive clouds of smoke billowing from the exhaust...i even warned the neighbours! To my surprise and mild disappointment there was no noticable increase in exhaust smoke from the normal exhaust smoke. Next step is to pull the intake apart and give it a good clean as described previously.
Thanks for all the input and information above, has been an interesting thread.
Yes we are still here :)
My 300RX has remained smooth and responsive for the past 10,000Km since stripping and cleaning the intake. It is using less gasoline than it did prior to the clean and is a joy to drive, I checked my plugs a few weeks ago and they are operating nicely with no unusual deposits.
Before you attempt the strip down, have a good look at the pictures that I posted previously, the only way to do it right is to remove the entire intake stack becuase there will be some SERIOUS gunk to remove after 130,000Km, but the results are worth the effort.
Post back here if you have any questions.
Edited by chad bob
Hi guys
This post has been an interesting read!! Which Nissan engines had direct injection rather than MPFI? I am wondering if I should fit the oil catch-can option to my Series II V35 with the 3.5L engine?
Even if not DI it probably makes sense to keep the excess oil out of the intake system?
Mike
A few people have complained of oil building up in the VQ35 intake as well, so it couldn't hurt.
Any Nissan engine who's engine code ends in 'DD' is a direct injected motor.
For our cars:
250GT / 250RS / 250RX = VQ25DD (Di)
300GT / 300RX = VQ30DD (Di)
350GT / 350RX = VQ35DE (MPFi)
  • 1 month later...
Sorry to drag up an old threat, but i'm going to tackle this next weekend.
Have already done the throttle body, as it was idling at 200rpm in drive, now 900rpm.
Any do's and donts I should be worried about? Under the intake stack, the ports that go into the black, are they ok to spray with carb/brake cleaner and then just engine start after?
It's at 180,000km, VQ25DD, doing spark plug's at same time.
I would be careful not to let the stuff run down into the intake. A small bent scraper and a vacuum cleaner should make sure that it does not fall down. In my case some of it did run down with the carb cleaner and the car ran a bit rough for a few minutes, but it promptly came right and has been fine ever since.
Just make sure that you dont scratch up / ding the mating surfaces of the intake components, theres nothing particularly tricky about this job and you can't really hurt the engine in the process, except perhaps if you scrape a cup load of the crud into the intake, which is unlikely.
Edited by chad bob
Sweet! Mine won't be so stagea looking soon.
Coilovers going in soon, not sure in the engine department but will be manual and turbo, either a VK45 or RB26.
Body-wise it will be all custom, i'm making my own kit for it, based off SuperGT/JGTC R35's.
  • 5 months later...
I attempted this engine cleaning procedure back in January but didn't get far. I dropped my 10mm socket onto the back of the motor as i was attempting to undo the EGR bolts. When i couldn't find it i lost my enthusiasm and put the throttle body back on. I had taken that off and given it a good clean but had hoped to clean out all the intake tract. Disappointed in my lack of mechanical skills and the fact that i lost my 10mm socket...i think it's still stuck somewhere behind the engine block on top of the transmission.
I may give this another go at some point as i'd purchased the cleaning gear to do the job. Will get myself a good set of ring spanners...i think they may help a bit.
Any advice in addition to what is already in the thread would be appreciated.
Just be careful, avoid getting cleaning detergent down into the engine through the ports. Make sure you clean all intake parts once removed, don't get under the bonnet with a hose I mean pinch.gif
Also be careful with the polished mating surfaces of the intake parts, treat them like CD's, put down rags before placing them on concrete and dont cink the rigid gaskets, they need to be nice and straight.
The hardest part of this job is getting round under the throttle to undo the EGR valve transfer pipe, it's a bastard every time, I used a $35 air powered 1/2" ratchet from supercheap. This way I didn't need room to swing the handle, just put on the socket and pull the trigger. This also comes in handy when doing oil changes, that under engine cover has too many damn screws! Your arm will fall off after undoing all those little buggers!
Finally do not over tighten the bolts when you re-fit everything, the intake does not need to be cranked down, all it needs is sufficient torque to provide a good seal.
Once you remove the top of the intake plenum you will realize that you did the right thing by deciding to clean the intake. It'll be a dogs breakfast in there if your cars done anything close to 100,000Km's !
Edited by chad bob
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
