actually was doing some test's on the free way last night
if i boot it it will stick @ 4.5 - 5k rpm.
if i ease it into the throttle it will go all the way to 8k without any problems at all..
im thinking fuel pump?
im thinking your coil packs are arching out.
is it a backfire or a boost miss?
backfire is where the engine has two much fuel put into it and it expels it in one burst out your exhaust.
could be caused by:
1. bad fuel
2. shit in the bottom of your tank if you had low amount of petrol
3. running too rich
but im leaning more towards checking your coil packs
I'm having the exact same trouble on my 33 gtst at the same revs, 3inch exhaust is the only mod. Replaced sparks with new standard coppers which seemed to clean it up a bit but soon after the problem was back, most of the time it's worse when the car has warmed up. Been thinking about getting some of those hks iridium plugs that can withstand more heat but at 19 bucks each it would be nice to know before hand if it's gonna help. Maybe check the gaps on your current plugs to make sure they haven't blown out and are in ok condition?
It's sort of a rapid "pop pop pop pop" coming from the exhaust like unburnt fuel is being dropped in to it, engine hesitates badly which causes the whole car to shake around a bit.
yeah, one thing to do would be to get a mate to drive from behind in your case and watch while it happens for smoke out the exhaust.
in your case but nicrwks, yours sound more along the lines of a boost missfire.
couple of things:
1: what rpm is this happening at?
2: what fuel is in your car?
3: how much boost you running?
couple of things:
1. Starts at 4.5-5k rpm right through to redline
2. bp ultimate
3. 7psi (no 2 stage)
Current sparks are NGK BKR6E
Alexxs: do you get the same popping sound around this rpm?
Edited by nicr4wks
yeah my issues start at about 5k rpm, its not a boost leak, ive checked that out..
im going to replace the fuel pump tomorrow, (tried today and fuel tank as full DURRR WHU?!?! im a retard lol)
and doing sparkies tomorrow along with taping up the coil packs i guess.
car hasn't been boosted stock 7psi
its frustrating sigh :teehee:
*edit*
im about 1/3 of my way through a tank of 98 with some injectors clears in it.
always run 98, vpower or bp ultimate.
Edited by Alexxs
Sorry for hijacking the thread. I've got back firing issues as well.
Mods:
Yellow Jacket Coil Packs
Plugs gapped to 0.8mm
3inch turbo back exhaust
Pod Filter
FMIC
I'm also still running the standard factory solenoid. Somehow when I'm flooring the throttle, I get up to 10-11psi of boost.
Anwyay, when I'm in 1st or 2nd gear and I back of the throttle at about 5000-6000rpm, I can hear back firing. There's no smoke coming from the exhaust.
Can anyone diagonse this?
Mods:
Pod Filter
FMIC
if it only happens when u back off the throttle id say ur running rich. really rich or ur fuel pump / injectors need a clean / replace.
hey everyone.. ive got a bit of a smiler problem but 10 times worse to the point that its not drivable :laugh:
about 3 days ago had my car parked outside a mates house.. and it was hell stormy weather.. anywayz i went to start the car it started then stalled.. so then i tried again this time it stayed on. but then as i went to drive off it stalled again. i noticed that every time i pressed the accelerator heaps of black smoke came out the exhaust which i know means its running rich.. but this wasnt just the usual lil bit of black smoke it was to the point where u could smell fuel and yor eyes would burn.. this obviously means that theres heaps of fuel that isnt getting burnt.
anyways i managed to get the car home and i took the coil packs out to look at them and there was water where the spark plugs are (decent amount). i drained it all out.. dryed the coils and put it back together started the car and its still doing the same thing. then i took the spark plugs out them and found that 3 of them were wet from the fuel.
this is obviously an ignition problem any ideas how i can narrow it down to wot part of the ingition system is stuffed? whats the best way to check the coils and the lil modual that sits on top of the plastic cover on at the back end of the engine etc??
help please!!!!!
    • Nah. Was just wondering if you were having a small stroke or if there was some slur/gaf/inside joke that I wasn't aware of.
    • That was a fark up, it's Salamanca Place I was thinking of. And now I'm curious as to what potential slur/gaf I have caused with Salamander Road, ha ha!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
