Hi, I'm new here and I've heard about some intresting engine swaps and engine combinations come out of Austrailia, like the RB30 with the 26 head, etc. I told my friends and they dared me to ask you guys to show us the craziest engine swaps Yanks have never seen! Show me V8s in S13s or any other work-inteisive but ultimately bizzare engine swaps!
There is one in this thread
S13 Conversion
Where the guy has put an RB25DET into his S13, added a second turbo (making it a DETT) and then replacing the turbos with HKS 2530s. Said to make about 400rwkw. I think that classifies as a crazy S13 swap.
Originally posted by neil_se
13b turbo, 2jz, 1jz, vg30det, rb26dett, rb25dett have all been done in australia. putting a v8 in would be sacrilege.
Even a twin turbo Nissan 4.5L quad cam V8? :)
Links/Pics please!:)
the last 3 of those conversion have all been performed by TTracing in brisbane. the rb25dett is (as far as is known) australia's fastest silvia, the vg30 is owned by the owner of TTracing but was only completed the night before jamboree so i'm still waiting to hear about it's power and times. his son owns an rb26dett silvia but i haven't heard much about that.
the 13b turbo silvia is also in queensland and is almost finished i think. i have heard of the 1jz and 2jz being done but i haven't seen them and can't exactly remember where.
rb25dett silvia
vg30det silvia
my mate, is using my old engine, making it around 200kw's at the crank (not much, but its remaining NA) before nos, and its going in his s13, its gonna be using 100hp+ nos setup.
Already been done... it's in Newcastle/Hunter in a shed (Maitland) except it's a nutso NA one with 8-throttle induction and mega-spec cams. Hooked up to Skyline 5spd 'box and GT-R diff that's been cut-n-shut to fit.
Yet to run more than a few hundred meters as it has problems with gearbox vibration they can't sort out once the car gets over 40km/h
There's also a Supra in Tas with a JGTC-spec 3UZ-FE in NA-trim.
Very cool...:D
Very cool...:P
Theres a what down here? Can't say I've heard of that beast.
And whats a 3UZFE? I thought there was only the 1UZFE 4.0l and the 4.7l 2UZFE in the Cruisers?
I'll believe it when I see it!
cheers,
floody
The 3UZFE is out of the Japanese Celsior... and I think its the Lexus SC430 in Oz?
Bugger the 3UZFE, someone should put the 1GZFE V12 out of the Toyota Century into a Trueno or an Altezza, cut n` shut, I know but... can you imagine?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
