OK - so most of you will be aware that DECA is coming up on Saturday 15th August and as always, the event wont go ahead unless we get enough people to help out.
So we are calling for your assistance - if your willing to help, or if your bringing a friend who's willing to help - please speak up
All officials will be given lunch and water etc during the day.
We also need all officials to be at DECA by 8.00am on Saturday morning - same time as competitors.
This is very important that we get people along to help for this stuff.... otherwise it affects everyone day...
If you see one of your friends standing around doing nothing, volunteer them for one of these jobs...
It will make the day run HEAPS smoother, which is better for you!!!
We need all the help we can get!!
Also remember, that these jobs all get you up close and personal to the action, and really gets you involved!
(Posistions are subject to change!)
Morning
Long Wang
Starter/Timer - Bec
Finisher/Timer 1- Dave
Finisher/Timer 2 - Rob
Flaggy 1 - Anna
Flaggy 2 - assyrian4evaa
Mini Wang
Starter - Campbell
Finisher/Timer - Tim
Skidpan
Timer/Time Recorder - Cassandra
Starter/Hat Removalist - RB_Ryan
Afternoon
Skidpan
Timer 1 - Anna
Timer 2 - Cassandra
Time Recorder -
Starter/Hat Removalist -Ryan/Crossy/Dave
Hat Removalist -
Look forward to seeing you all up there!!!!
https://www.sau.com.au/forums/topic/278160-micolour-sau-vic-deca-volunteers/
I'll put it too the Mrs.... She might time for half a day if that would help? would want to be able to take her as a passenger still, and would want to be timing the group i am in so she can watch though(no dodgeyness haha)... guessing BYO deck chair? :(
we need the most volunteers in the morning, from 8am to 12:30... after that we only need a few so there will be plenty of time for passenger rides in the afternoon..
the afternoon will also be the better time for spectating
Ill be there again.
Can I plz be put as flaggy on Long Wang in morning and if you need me in the arvo let me know and I can help then too (otherwise Ill just be standing around doing nothing!)
Great work guys.. have added you name to the list...
Keep them comming people!!
"Remember without these nice people that help us out... there wont be an event..."
I know people probably get tired of hearing that saying... but sadly it is true!!
So make sure you round some mates up!
it is simple as it sounds... But definately don't worry about asking nooby questions...
I would rather you ask questions and know what is goin on, rather than hold up the days events becuase you don't.
basically there is a finish gate at the end of each map.
The gate is made up of a series of cones designed so that you have to stop completely within it its walls.
Once you have come to a stop, your time stops.
A volunteer is then required to remove the cone from in front of your car so you can drive forward and move on the to next event.
Watch some of the videos people have posted and you can get an idea of what i mean.
Its nice a simple! And you get to be right up close to the action.
It basically just helps to keep everyone moving so we turnover cars at a faster pace...
OK people... have updated the list.. made a few changes and added a few people...
Let me know if you have a problem with where i have put you... they still might change.. but i think it should be pretty good like this...
Also if your not sure about a job just ask me either on here or PM...
Look forward to seeing you all up there bright and early!!
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
