Adam, I am running a HKS adjustable actuator (set to 15psi I think) and my controller is a greddy profec b spec 2. Both were installed and setup by CRD.
So CAN the coils effect boost control as Jim told me??
Jim is one of the best tuners in Australia. Believe what he says over anything you read on an internet forum :)
The coils breaking down will mean the engine cant run properly so all bets are off - power, boost, everything. There's no way to tune properly in that circumstance. Incomplete combustion mean less exhaust pressure, so compromise the turbos ability to produce boost.
You're boost control setup is fine. Give Jim another crack. If the boost still drops off then you'll have to look at the turbo.
Oh that should be "look at the turbo or exhaust, exhaust first. Exhaust is easy you just drop it at the front pipe to cat connection and take another run. If the boost holds then you need a better exhaust, if the boost still drops you need a bigger turbo."
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
