for a while my R33 gtst has had a screeching noise coming out especially on cold mornings where i had my new timing belt put in.
i took it to my mech and he said not to worry about it so naturally i went to another mech in town who took a look at it and my timing belt was about 1cm thick in width and he said he was amazed it hadn't snapped and seized my engine up.
he told me to take it back to the mech who originally put it in cause it should be under warrenty so i went down there and left my car there over night.
went back today and he reckons he cant find anything that is causing it except one of the bearings was a bit loose but he doesnt know if that was causing it so i had to get new bearings and a timing belt and new cam gears which i have to pay for which i think is bulls***!
do you guys know what could have shredded my timing belt like that?
https://www.sau.com.au/forums/topic/278457-timing-belt-problema-mystery/
Honestly i think the first mechanic installed it wrong, its probably not aligned straight so its grinding against something. id get another mechanic to put in a new one and take photos of the shredded timing belt so you can possibly be reimbursed by the first mechanic.....long shot i know
My advice is not to ever let the first mechanic look or touch your car again, never leave it there overnight or let them "fix" their first job....
Just get your cash back if you can, fight them, if you still cant then don't be too upset, your car is still driving after being butchered. Find a reputable mechanic in Sydney to have a look at it.
GL with it mate
This may not be the same problem at all, but...
My Prelude had a split/shredded timing belt at 218000Km ie. not even 20xxxKm after the new belt was put in.
I was left stranded with no compression in the cylinders after taking off from the lights & the engine went dead.
The car went back to my mechanic, who found out that a B/T Bolt that sits on top of the hydraulic tensioner and acts like a pivot point snapped, causing the belt to shred lengthways right around the circumference. Fortunately, the valves weren't 'kissed' or bent. There were fatigue points near the fracture, which meant that the bolt had been bent over for some time before it finally broke.
So if it happens again... :thumbsup:
Yeah thats pretty unusual im struggling to think what really might have caused that to happen.
Maybe it was over tightened or something.
But it should sound the same when you pick it up as when you left it. You have to accept mistakes happen, manufacturing faults happen. Because its under warranty you should leave it to the mechanic to rectify it at no charge. I was working in a small workshop once and we changed a few cam belts with kits from a reputable supplier only the bearings kept failling one or two weeks later. we had to then waste hours of our time swapping them out only to get a cost refund from the cambelt kit people with no explaination. coping angry customers left right and center.
You should not be charged for the bearings and belt if thats what you paid for and screwed up.
The timing belt was probablely rubbing on something eg the timing belt cover.
i had the same problem with my r33.
i used to head this weird noise (screeching/Whinin Loud) after a new timing belt was installed. i was told its normal for new belts to do that. and it was a Gates racing belt so i heard its normal with them.
i forgot about it and one morning at 4am when i was on my way to work i started hearin this loud ticking noise which used to go away when i Rev over 2000RPM. i got scared parked at a gas station.....
then decided to continue driving without letting the car rev below 2000RPM and went to work all the way to Armadale from Bentley(stupid i know but had no choice was already halfway there). drove back from armadale after work same way.
Got it towed to the workshop who did the timing belt thing a few weeks ago and they sed that i had snapped a bolt that holds the tensioner pulley, maybe because the belt was too tight. but i was lucky the belt was still on and there was no Engine Damage.
They had to fit a new tensioner pulley and new Timing belt all for FREE :rofl:
I dont think they shud make u pay for it... u PAY them to fit a new belt. u Drive the car coz thats what its meant for... the car suddenly has a problem wit the timing belt? I SAY THEY PAY
Ive got an update for you's.......
the 1st mechanic is a d*** head and will not be getting paid and i will never go to him again!
i took it to another mechanic who does alot of work on imports in my town and i told him about what happened and it turned out it was my alternator belt that was doing all the screeching and it was luck that i mentioned that it may have been my timing belt and found out what was happening to it,it was rubbing/shredding because the 1st mechanic didn't fit it properly.
so naturally the import mechanic wanted to have a look at the newest timing belt the 1st mech had just installed and guess what........it was doing the exact same thing again,it was already showing signs of wear so he fixed it properly for me and he didnt even charge me he said it was on the house.
he said he reckons the 1st mech was doing this on purpose thinking if it kept stuffing up i would keep going back to him so he can keep milking me or he was retarded.
Wow, didnt expect that. Definitely stick with this mechanic as he seems to have some integrity.
Businesses dont know about customer relations, you cant survive on a single customer coming once; word to mouth will bring the customer back with his friends.
Glad you got it fixed mate
I cant belive how inept your first mehcanic must be changing a rb timming belt takes like an hour max and is one of the easyest timming belts to change "id hate to see that guy try a twin cam v6" you should post his name or business name so others dont make the same mistake...
maybe we should start a bodgie backyarder thread or somthing so we can list all these half assed grease monkeys
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
