No, not unless your bonnet doesnt have a 2nd click when you shut it.
Eg, if you pull the bonnet lever from in the cabin and it pops up then WITHOUT lifting the latch behind the grill the bonnet will open all the way, then you'll need the rope. Otherwise the first restraint is the latch from inside the cabin, second restraint is the latch behind the grill
Make sense?
How hard is always a tough one, it really is up to you.
Basically each course last about 50-70 seconds, then you rest, mostly first maybe second gear. A few starts and stops.
My opinion is it really isn't that hard on your car, but if you choose to do 7500 rpm launches, drift the course and slide into the box on the hand break then things will wear out quicker. It is also worth servicing your car before any motorsport event. :)
Having said that, this is awesome value and a great way to get a taste for motor sport without huge expense and in a friendly fun environment. An opportunity not to be missed.
Hope this helps.
Dan.
I just rolled my ankle really bad......wont be driving for some time. If I am ok before this and there are still spots, I will attend
I had a full ankle reconstruction 8 weeks ago, I'm going to the track tomorrow. You'll be right sugar blossom.
i wouldnt mind coming out. Only just brought my gtr, not to keen on putting the gearbox though the floor. How hard is it on ya car..... prob a stupid question aye
Generally its not as hard as a "spirited" drive through old pac :)
Go as hard or soft as you like. If you're going too hard ill tell you, if you want advice etc on the day, there will be heaps of people around who can help.
Its a day of fun, nto trying to get the fastest time of the day, so come along and go at your own pace, its great using a GTR off the street :)
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
