Hi All,
Unfortunately on Sunday morning just gone, my R33 GT-R Skyline was broken into and a few parts have been taken from the engine bay and some parts from off the ground.
The parts stolen :-
- Garrett GT51R Turbo KAI BB with a polished compressor cover with a .91 rear housing and TV flange.
- 6Boost manifold to suit RB26 head and has a 60mm wastegate pipe.
- Set of 4pot front Brembo brake calipers.
The build for this skyline is near completion now with only a few minor things left to do but unfortunately due to this inncident, it's now set us back.
The turbo and manifold are not your every day item you buy so if anyone hears of anything, see's anything or has or will read of anything on any other forums that is being sold of this discription, please can you contact me ASAP!!!
Contact Number - 0420 615 315 (If I do not answer, please leave a message or SMS with the details and your contact details please!!!)
There is a reward for information that will lead us to these items.
Any help you can provide also would be much appreciated.
Items were located in Ipswich, QLD.
These are some pic's of the manifold, I don't have any of the turbo on it's own except before it was polished.
So I've attached the ones I have with it bolted to the engine.
Guys... sorry I've put the wrong turbo in...
It's actually a Garrett GT51r.
Also with/on the turbo there will be the speedflow fittings, the special custom made chrome painted -12 oil drain fitting and a blue Earls -4 oil filter
This is a pic of it before it was polished.
https://www.sau.com.au/forums/topic/279071-stolen-parts/
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
