Once the car is in your name, you can file for a refund on the remaining interstate registration. If it's NSW rego just go into the RTA in Queanbeyan, but if it's further than that then you're best off mailing a letter requesting the registration be canceled and the remaining rego refunded to you. You have to provide receipts for the surrender of the plates, which you should have got from the shopfront when you swapped rego over.
In my case when my car was stolen and written off, it still wasn't in my name yet, so the only way to get the remaining 8 months of rego refunded was for the previous owner to do it. It was only going to be like $150 anyway, so I really couldn't be stuffed driving to Goulburn to get him to do it (and of course splitting it for his troubles)
Hope that helped a little :blink:
https://www.sau.com.au/forums/topic/279258-act-rego/#findComment-4716342
i had to remember how to find it......
http://www.vicroads.vic.gov.au/NR/rdonlyre...ndsform2008.pdf
i saved it onto my computer. you will need to send the reciept for the plates, along with this from, that you will get after transfering the rego to ACT. i got $116.xx back for just under 3 months of rego.
https://www.sau.com.au/forums/topic/279258-act-rego/#findComment-4719618
I'd just use the interstate rego and change over to ACT rego around a month before it runs out.
You generally get no-where near the amount back that rego costs and there is no late change of ownership fee for an interstate rego car being changed to ACT
https://www.sau.com.au/forums/topic/279258-act-rego/#findComment-4719837
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
