The synchro switch locks on the awd to give 50/50 front/ rear drive when you start off. At higher speeds the computer takes over again and sends most drive to the rear except when the rear starts to lose traction.
thanks for the response
then you have a problem with your alarm/immobiliser. or if you dont have aftermarket, then you might have a door switch problem
hmm. will check this out. i do have the book for my immobiliser so will have a read.
Glad to see I'm not the only freak....once swapped cars with my wife on a drive just so I could see it moving...lol....she only got it for 5 minutes though....then I had to have MY PRECIOUS back!!!!
LOL at "MY PRECIOUS".
..... I ..... understand ;)
This car jsut gets better and better. 3/4 of the way thru our 4000km road trip and im still amazed by it. with over 200kg worth of stuff thrown in the back and the two of us in the front the stagea still gets up and boogies. my old skyline if i babied it got about 350 to 400 km to a tank with the rb20 in it. the stagea is a freak pulling over 600km to a tank!! is there anything these cars cant do haha.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
