Hey all Just dropping a line to ask a few things,
When you take the plumb back off the bov but stock Bov is still there, why does this cause Idling/Stalling problems an sometimes backfiring?
When installed a atmo bov i think, a HKS sequental (not new one) still had some idle issues.
Also say when your in parking rev the engine to bout 4K rpm it will drop down to 1K then up its self to 1.5K before dropping again?
Proberly stupid questions but any insight on this would be great.
Cheers
https://www.sau.com.au/forums/topic/279586-bov-querys/
the factory bov is open at idle so un airflow metered air is coming in so ecu puts in not enough fuel or too much fuel . adjust the spring pressure on the hks one so it is closed . idle is also becaus of the same thing
https://www.sau.com.au/forums/topic/279586-bov-querys/#findComment-4720696
Search. This gets asked 3 times a day.
You cant nicely run an atmo venting bov with the stock ecu.
The AFM reads X amount of air and the ECU fuels for that. Then when you lift off the accelerator, it dumps a part of that X amount of air.
BUT the ECU doesnt know that, and still fuels for the original X amount. Therefore its now overfueld. Thus your stalling/backfiring etc.
Just stick with the stock BOV with Stock ECU. Unless you get an AM ECU or piggyback to tune the overfuelling out, it will keep doing it.
https://www.sau.com.au/forums/topic/279586-bov-querys/#findComment-4721288
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
