What the photo doesnt show is that the s-pipe is useless without the second part i thought i was getting. he then "found" the second part and offered to send me that,Much like he sold me the plenum then called and said Oh I "found" you will need the S-pipe
The guy Bull#$%ed about having sent the S-pipe several times to me I missed my dyno booking. When it did arrive poorly packed(in an envolope) and in bad condition, i discovered it was useless to me.I would not spend 8.5k with someone who has show himeself to lack any sense fairness in a a $250 transaction.
You will probally find you wont get your rings or pins or something like that, maybe he will "find" a 6th piston after sold you 5.
I sent you exactly what was advertised and in the photograph ! if your mechanic didnt know how to fit them it time for your dyno run not my problem . you got exactly what was advertised.
Sold $5000 dollar set of endless brakes to adam on here last week he was more then happy with my photos and description. sold $1600 tomei head, apexi rx 6 turbo $1500, another Modified head $1500, sequential 6 speed trust box $10,000 NO complaints ! i could have sold the part to other people at the time, but you said "no you had already put money into my account" you were that certain about part you didnt even say ill take it - you just put the money into my account.
just got brand new HKS individual prices for pistons rods and crank
pistons 3340
rods 3870
crank 9239
so if i was to split into the three parts the amounts stated earlier for individual parts would change. my mistake sorry
Edited by 555kkk
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
