What the photo doesnt show is that the s-pipe is useless without the second part i thought i was getting. he then "found" the second part and offered to send me that,Much like he sold me the plenum then called and said Oh I "found" you will need the S-pipe
The guy Bull#$%ed about having sent the S-pipe several times to me I missed my dyno booking. When it did arrive poorly packed(in an envolope) and in bad condition, i discovered it was useless to me.I would not spend 8.5k with someone who has show himeself to lack any sense fairness in a a $250 transaction.
You will probally find you wont get your rings or pins or something like that, maybe he will "find" a 6th piston after sold you 5.
I sent you exactly what was advertised and in the photograph ! if your mechanic didnt know how to fit them it time for your dyno run not my problem . you got exactly what was advertised.
Sold $5000 dollar set of endless brakes to adam on here last week he was more then happy with my photos and description. sold $1600 tomei head, apexi rx 6 turbo $1500, another Modified head $1500, sequential 6 speed trust box $10,000 NO complaints ! i could have sold the part to other people at the time, but you said "no you had already put money into my account" you were that certain about part you didnt even say ill take it - you just put the money into my account.
just got brand new HKS individual prices for pistons rods and crank
pistons 3340
rods 3870
crank 9239
so if i was to split into the three parts the amounts stated earlier for individual parts would change. my mistake sorry
Edited by 555kkk
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
