Hey guys and girls,
Im buying another car as ive sold my GTR.
Ive found one i like and ive put down a deposit.
He has said he had to take a car loan out to buy the car and is still paying it off.
As me the buyer what do i have to do differently ? if anything?
As ive never bought a car that is under finance.
https://www.sau.com.au/forums/topic/280046-buying-a-car-with-a-loan-on-it/
Wouldn't you need to find out how much he has left owing on the loan and then ensure that the money you are paying him for the car is going to that loan, rather than in his pocket?
So, payout the loan (thus car is fully owned by the seller), than whatever is left behind goes into he's pocket.
Think that would be the procedure
In this case lets just say the dude is selling his car to you for $15K....he has $10K owing to the bank....then what you would be doing is paying $10K to the finance company (in this case BANK) and giving the DUDE (the seller) his $5K.....i would be personally going to the bank and asking them for advice and they will be able to point you in the right direction and at the same time organise everything for you.....
if you paid the DUDE $15K and he does a runner.....guess what....your the owner of the new vehicle....and you most likely will be required to pay the payout amount.....
Same with insurance when your car is financed....the insurance company will payout (in case of a writeoff) the financial company what you owed them and then give you whatever is left
TREAD WITH CAUTION ON THIS ONE MY FRIEND
Yep all the advice above is spot on...
Get payout figure on his loan, make out cheque to his finance company, then cash for any difference or seperate cheque. Do the signing of changeover forms at the bank when he deposits the cheque(s) and MAKE SURE YOU GET A PRINTOUT SHOWING ZERO BALANCE ON THE LOAN!!!
Good luck.
well i have a contradicting story. When i purchased my s14 the guy had finance on it. I paid him, he continued paying his loan. When i went to sell it a guy backed out cause he found out it still had a finance against it so i called the company the finance was with and questioned them. 2 different times i rang to be sure i was getting the right answer and they informed me that if he did a runner they would be chasing him for the money as the finance is in his name. They wouldnt be involving me at all, be it for the car or money. Havnt heard from them to this day and i see the car kicking around every now and then.
As Luke said, the only time they will come chasing you is if the loan was secured against the car. In which case the bank will order repossesion papers for the car if the person named on the finance defaults. But i could be wrong, had a similar situation a few years ago too.
James is correct.
If the owner took out a personal loan to purchase the car but wasn't secured against the car then you'd be safe buying it cause if he did the runner the finance institution would chase him.
However, if the loan was secured against the car, either pay the finance company direct (and make sure you keep the receipt and have the rego papers) or avoid it with a 10ft pole.
Thanks for the advice. As it turns out its only a PERSONAL loan not a loan on the car so its fine. But as said above IF it was a car loan. Best way to do it (or as i was told by his bank) would be to go in with him to the bank with the cheque and pay it out there and then with him. theyll give you the loan payout statement there and then
Even if its a personal loan it can still be secured agasinst the vehicle. But yeah, do as you said and be there when its paid out and get a print out of the balance sheet for the loan. Probably wouldn't hurt to ask if it can be closed while your there too.
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
