Hi guys,
Battery went flat a few days ago, battery is about 6 years old as it is an 03 model. Battery cells were gone.
Had the battery replaced. Went to the petrol station to fill up about 3 km's down the road. Locked the car then unlocked. Went to start the car and the rpm's went up as normal then dropped which lead the car to turn off. Oil, battery and engine light came on. Second attempt same symptoms. Third attempt turned on however this time the rpm completely dropped just above 0 then all of the sudden went back to 700rpm drove off as car was running. On the third attempt it almost sounded like the car wanted to turn off. Got home locked the car and left it locked for about an hour, i again attempted to turn the car on same thing engine turned on, rpm dropped all the way and turned off.
Please help my auto electrician does not know what is wrong with the car, it is the first time he has worked on a car like this.
Kind Regards Yianni
https://www.sau.com.au/forums/topic/280543-2003-350gt-coupe-starting-problem/
Hi Chris not to sure.
I have been doing some research on a few infiniti websites and sourced another person that had the same problem. He referred to the procedure on how to reset the ecu, throttle pedal release and idle air volume learning and it seemed to have resolve his issue so i might give that a go. Its definitely not an immobiliser problem as for starters the car would not even turn on. Apparently the battery of the car was disconnected overnight so it reset the ecu however the auto electrician didn't teach the ecu which regulates the idle etc.
Edited by T88turbo
hey guys this might sound realy stupid, though i had the same problem, and it wasnt my ecu or battery... it was acutally my spark plugs..... when was the last time u checked your plugs? see if there is any oil getting to these plugs, if so see a mechanic.
Nope plugs were replaced 2 months ago.
It only happens on hot starts, its all normal when the engine is cold. This is because when the engine is hot it does not need to rev high, revs drop instantly to about 600rpm as normal.
Stuff it im going to take it to nissan, i bet you its the ecu that needs to be programmed. Remember the ecu regulates the idle, and a thousand other things. I tried this procedure on the infiniti website that resets and teaches the ecu but it didnt work.
Here is the link if you need it.
http://www.nicoclub.com/articles.php?id=356397
Now that you mention it, my 300gt has been doing this as well..
On hot starts, revs drop really low and on a few occassions stalled. Most times, after starting, I just rev it a little and its all good.
has never stalled on me when actually driving only when starting the car. Might have to look into it a bit more.
thought about the fuel type you have been using?? i have another car that has trouble starting when i use shell fuel. BP and mobil have been fine. friggen italian cars! lol
it might be as simple as that for you
hi bilistic,
Did you have your battery disconnected more than 24 hours? I can understand the ecu learning your driving habbits however how does it learn not to stall on hot start ups by reving it are you sure this worked? and did it stall at the beginning when you had your battery changed? I can't understand why it doesnt stall on cold start ups???
hi bilistic,
hey mate
yeh i had my battery disconnected for over 1 week when i installed the plenum spacer (long story lol)
when i finished the install i reconnected the battery and i did an ecu reset straight away before i even started the car again
the car started fine and i took it for a 20min test drive for the ecu to start learning again. i got home and parked the car. i had to move the car again after 5 min and when i started the car - stall.
It kept doing this for about 1 week. Cold starts were always fine. Any start where the engine went into cold start mode (higher revs than normal) it didnt stall. When it was hot (example, went to petrol station to fill up, turn on car - stalled) the car stalled. To get around it stalling, every time i started the car i just blipped the throttle to make sure it didnt stall. I was doing this so, that like you i was going to go and get it checked out.
However, after about 1 week, the problem went away. now i can start my car and its like back to normal again.
Hope this helps.
I use BP Ultimate 98 Octane all the time since i have had the car, and the previous owner did also.
Edited by BLISTC
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
