  • Replies 129
Posted Images
Still working on the list but first thing that has to go is my Gram Lights 57F Pro Titanium Lip Wheels 18x10 +20, will fit R33 and R34 GTR's but will not fit a R32 as I have tried it on ours. Also the Rear Spoiler has to go, Iwant to sell it as a whole it is a Original R33 GTR Spoiler with Nismo Carbon GTR end caps and a Genuine Autoselect Chibi Devil Carbon Blade. Sill don't know if I am going to enter in the Clubsprint or Open Class yet its a hard decision.
  • 4 weeks later...
Hi all
I have had another change of heart again for the millionth time, Decided not to get the Evo X, and not strip the GTR into a track car as this was gonna cost lots of $$ to do. I'm just gonna try make it the best god damn Street R33 GTR in Oz, so i decided to do a lil bit of shopping today and shout myself some Awesome and Rare shiny bits for the GTR. I was so close to buying a Nismo Plenum and the HKS V-Cam Step 1 kit today, if someone was here to edge me on i probably would have bought them (thank f**k Kingy is at work he would have twisted my arm for sure rolleyes.gif). But after some quick research i quickly changed my mind. I Could of got the same result by chucking one of my 3L Blocks in (they get used one day) if i wanted better response. So the car will be pulled apart a lil bit longer till my new parts turn up, it will be like Christmas when this order rocks up this time banana.gif. I have now successfully obtained the full Ikeya Formula Catalog now (except the tie rod ends) i have the Moonface Racing ones which are a bit more heavy duty then the Ikeya Formula Ones. Anyways i am now waiting patiently for this next order can't freaking wait woohoo!!!!! so excited.
Heres the List of whats to come:
- Ikeya Formula Roll Center Adjuster Lower Front
- Ikeya Formula Roll Center Adjuster Lower Rear
-Cusco Tension Rod Bar
-Moonface Racing Super Hard Tie Rod
- Mines Cam Baffles
- Sunline Racing GT Spec Titanium Front Pipe
- Fujimura Auto Rocker Dancer Titanium Strut Brace
Done a bit of work to the car today, all the wiring is pretty much sorted, installed a innovate AFM Gauge today and put the new Bride Floor Mats in. Have ordered the Bride Material for the back seats yesterday and should have that next week, then i'll pull the back seats out to get re-trimmed in black leather with red stitching next week hopefully. I Also mounted my new Billion Power Steering tank and decided to put the original Nur Front Cam Cover on aswell, piss that shitty carbon one off. Here's some pics:
  • 5 weeks later...
Update time:
Now the R32 is almost complete my latest shipment of goodies have arrived for the R33. The workmanship in the titanium front pipe and strut bar is just awesome and some of the best work i have ever seen, and the Ikeya Formula gear is built super tough will not be breaking them any time soon. I have installed the rear Ikeya lower arms, might do the front ones tomorrow, i also have to re-torque the cylinder head on the R32 and change some settings in the Vipec is also on tomorrows list as well. Can't wait to hear the full titanium exhaust at 8500rpm gonna be on par with the R32 (maybe). Anyway hears some pics:
Just a note on the ARC airbox, mine sucks the filter in on less power than you're going to make, so i'd suggest putting a cross brace under the filter to support it in the centre :)
Does your Arc Filter Element have a steel mesh built into it, it would take a fair bit of suction to suck that in, I can't even push it in with my hand. But ill keep an eye on it cheers N1GTR thumbsup.gif
That's some mad aero... love it! Canards, lips, diffusers, wings, sills = the burger with the lot! And that's your daily?!?! Madness... I have a Ford Fiesta XR4 as a daily, now that's a daily! Jealous? I guess not :(
Lol its hasn't been a daily driver for awhile now been on the hoist since Xmas, but yeah i plan on racking up some kms on it when its done and do some cruises with the R32 as well. The coilovers are Tein Mono Flex's F=8kg/mm and R=7kg/mm they are perfect for street use not to harsh i have found the Tein Super Streets to be to soft on some cars. I will probably save up for some track spec Ohlins or Teins for when i hit the track and a new set of rims.
P.S i have an obsesion with carbon and titanium the damn things are sending me broke :banana:
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
