  • Replies 129
Posted Images
Still working on the list but first thing that has to go is my Gram Lights 57F Pro Titanium Lip Wheels 18x10 +20, will fit R33 and R34 GTR's but will not fit a R32 as I have tried it on ours. Also the Rear Spoiler has to go, Iwant to sell it as a whole it is a Original R33 GTR Spoiler with Nismo Carbon GTR end caps and a Genuine Autoselect Chibi Devil Carbon Blade. Sill don't know if I am going to enter in the Clubsprint or Open Class yet its a hard decision.
  • 4 weeks later...
Hi all
I have had another change of heart again for the millionth time, Decided not to get the Evo X, and not strip the GTR into a track car as this was gonna cost lots of $$ to do. I'm just gonna try make it the best god damn Street R33 GTR in Oz, so i decided to do a lil bit of shopping today and shout myself some Awesome and Rare shiny bits for the GTR. I was so close to buying a Nismo Plenum and the HKS V-Cam Step 1 kit today, if someone was here to edge me on i probably would have bought them (thank f**k Kingy is at work he would have twisted my arm for sure rolleyes.gif). But after some quick research i quickly changed my mind. I Could of got the same result by chucking one of my 3L Blocks in (they get used one day) if i wanted better response. So the car will be pulled apart a lil bit longer till my new parts turn up, it will be like Christmas when this order rocks up this time banana.gif. I have now successfully obtained the full Ikeya Formula Catalog now (except the tie rod ends) i have the Moonface Racing ones which are a bit more heavy duty then the Ikeya Formula Ones. Anyways i am now waiting patiently for this next order can't freaking wait woohoo!!!!! so excited.
Heres the List of whats to come:
- Ikeya Formula Roll Center Adjuster Lower Front
- Ikeya Formula Roll Center Adjuster Lower Rear
-Cusco Tension Rod Bar
-Moonface Racing Super Hard Tie Rod
- Mines Cam Baffles
- Sunline Racing GT Spec Titanium Front Pipe
- Fujimura Auto Rocker Dancer Titanium Strut Brace
Done a bit of work to the car today, all the wiring is pretty much sorted, installed a innovate AFM Gauge today and put the new Bride Floor Mats in. Have ordered the Bride Material for the back seats yesterday and should have that next week, then i'll pull the back seats out to get re-trimmed in black leather with red stitching next week hopefully. I Also mounted my new Billion Power Steering tank and decided to put the original Nur Front Cam Cover on aswell, piss that shitty carbon one off. Here's some pics:
  • 5 weeks later...
Update time:
Now the R32 is almost complete my latest shipment of goodies have arrived for the R33. The workmanship in the titanium front pipe and strut bar is just awesome and some of the best work i have ever seen, and the Ikeya Formula gear is built super tough will not be breaking them any time soon. I have installed the rear Ikeya lower arms, might do the front ones tomorrow, i also have to re-torque the cylinder head on the R32 and change some settings in the Vipec is also on tomorrows list as well. Can't wait to hear the full titanium exhaust at 8500rpm gonna be on par with the R32 (maybe). Anyway hears some pics:
Just a note on the ARC airbox, mine sucks the filter in on less power than you're going to make, so i'd suggest putting a cross brace under the filter to support it in the centre :)
Does your Arc Filter Element have a steel mesh built into it, it would take a fair bit of suction to suck that in, I can't even push it in with my hand. But ill keep an eye on it cheers N1GTR thumbsup.gif
That's some mad aero... love it! Canards, lips, diffusers, wings, sills = the burger with the lot! And that's your daily?!?! Madness... I have a Ford Fiesta XR4 as a daily, now that's a daily! Jealous? I guess not :(
Lol its hasn't been a daily driver for awhile now been on the hoist since Xmas, but yeah i plan on racking up some kms on it when its done and do some cruises with the R32 as well. The coilovers are Tein Mono Flex's F=8kg/mm and R=7kg/mm they are perfect for street use not to harsh i have found the Tein Super Streets to be to soft on some cars. I will probably save up for some track spec Ohlins or Teins for when i hit the track and a new set of rims.
P.S i have an obsesion with carbon and titanium the damn things are sending me broke :banana:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
