  • Replies 66
Originally posted by Nizmo
No car for me ;) ...... tommorrow ..... like im going to believe that for a second!
phuck!
Don't get your hopes up. It will always take longer than expected.
And everyday when you make that last phone call, you'll be let down and it will f#ck your whole day.
And then you get it back and your #3 piston is f#cked, oh no, that type of thing only happens to me.
You'll get it back soon.
Sorry niz, that may have sounded a tad bit freaky...
I ment it in a nice encouraging way... not a way like paul would (sorry paul, your a easy target)
if it make you feel any better you can take my car for a fang to get you excited again... when i took paul for a fang in it ages ago, i got a smile from him...
Didnt get it last night either ..... major wars going on between my dad vs panel beater :( Everyone cross their fingers for tonight ..... im having serious Skyline withdrawls and im about ready to set that phucking Laser alight!
Nate ... haha i knew what you meant :) thanks! If i dont get my car back tonight i might have to take you up on that offer!
Adrian thanks babe! Its a very small club ...... not like the GTR wing club :bahaha: we're speshal
haha your a brave guy Nate :) Thanks Heaps :grouphug:
fingers x'ssed for tonight because i dont think i could survive a 2.5hr trip down to Bunbury on the weekend without music (lasers radio doenst work :( )
Yeah lets create a SAUWA posse ..... barge in there and intimidate them! :bang:
Can i still chain myself to the gates Greenpeace stylin' with "Save the Black Whale' sign?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
