Great fun guys...Great fun!
The best part was (I think) after the U Turn :( Everyone had a little fun through the cane fields, Thanks to the Bayside crew..How about a regular meet guys??
PS..Was i the only 32 4 Door representing??
Great day and had an awesome time (even the g/f didn't mind it!), definitely up for bayside meets and looking forward to more events.
Sorry I didn't say goodbye Jay, couldn't see where you got to but had to head, I'm chasing zennon for pics too :devil:
Good meeting you Noel, total gentlemen to a total stranger, thanks again.
A few pics taken from my phone:
  • Replies 286
Posted Images
I had a bloody great day!
A huge thanks to those that came out to support YoungCare (please take 2min to visit their website). http://www.youngcare.com.au
BBQ duty was 1000% better than last year - what a great day, warm but NOT too hot! Hope you didn't get one of the 'well done' snags :devil:
Yep. the dirt road was a big surprise to ALL of us - it wasn't there when the scouting run was done 2 weeks ago!
2nd Huge thanks to the Club EXEC, Members & Friends for helping out on the day.
Another HUGE thanks to the Club Sponsors and Supporters of SCC!
For those that missed out, here's the map (u turns and all), sponsors/supporters and upcoming events.
Map_Final.pdf Sponsor_SCC09_01.pdf SauQld_Event_Calendar2009.pdf
In the end, we had approx 95+ Cars, only a few down on last year's numbers.
Looking forward to seeing more photos!!! - And thanks to JustDave for shooting the cruise!
See you at the next event!!!!
Cheers
Yeah was a good day, good to meet you guys and would be keen for Bayside meetups!
Now, where are the pics Zennon!? haha :(
Here are some random shots i took with my little point and shoot kodak thing.
yeah, would have been nice. Guess people don't get rich and afford to buy R35 by being charitable. haha, juuuuuusssttt kidding. *back pedals*
hahaha I can't imagine an owner of an R35 being impressed by the dirt road and gravel though lol
When's the next one?
2010 lol
Ah was that JustDave! I feel previlaged to have held his light reflector for the Noel engine bay shot then :thumbsup:
I'm chasing zennon for pics too :)
Now, where are the pics Zennon!? haha :)
I'll upload (and link) my pics shortly - my PC is just quickly (read: painfully slowly) stitching together a panorama
I wonder how much does it cost to mod the stagea with the 34gtr kit. I would love to have that 35gtr stagea as a family car though...
$4.5K in parts plus head lights just for the front end.
Plus paint and DIY fitting.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
