Item: rb20det random engine parts
Website: here & other
Item Condition: yer good
Reason for Selling: no rb20det anymore got rb25det power now :down:
Price and Payment Conditions: prices a sort of neg so make some offers i'll see what i can do!!! :) vvvvvvvvvv
Extra Info: rb20det random engine parts
Pictures: yep along with prices vvvvvvvvvvv
Contact Details: reply here or pm
Brand New Rb20det Airflow Meter Silvertop $130
rb20det coils packs great condition $130
rb20det afm great condition $60
rb20det stock ecu great condition $130
rb20det igniter $40
rb crossover pipe $50
rb20det starter motor $40
rb pulley $25
Nissan R32 Skyline RB20 RB25 RB26 engine service manual (Printed and hole punched in binder folder- Hardcopy)
HARDCOPY VERSION OF A ENGINE SERVICE MANUAL FOR NISSAN SKYLINE R32 ENGINES
THE ONE MANUAL COVERS THE FOLLOWING ENGINES...
RB20DET,
RB20DE
RB25DE,
RB26DETT + More
All engines are covered for maintanance, dissasembly, installation and repair! Including torque settings, bearing sizing, troubleshooting, diagnosis, etc. These manuals are all in English (which is extremely rare as it is!)
This manual is printed double sided, hole punched and set in a lever arch binder. Over 600 pages! No more having to go back to the computer to refer. Reference can be made where you work. Garage, Workshop, on the road, etc.
https://www.sau.com.au/forums/topic/281482-rb20det-random-engine-parts/
  • 1 month later...
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
