I was just wondering if any of you want a cheap front cut of any sort.
Eg. Getting a GTR 33 S2 front cut & transferring Dash, engine gear box, flared guards, bonnet, etc onto a GTST. Not to sure if the front wheel drive will be possible thou.
If any of you are interested in getting one, just either PM me or reply to this thread. I'll get prices and pics and then we can go from there.
Cheers
https://www.sau.com.au/forums/topic/28154-expressions-of-interest-front-cuts/
This is not a business thread. I need some people to make up numbers to fill a container full of parts and half cuts. So we can get it all cheap....
Prices cannot be obtained until I can get a list of parts and half cuts.
Cheers Guys
i nned some parts so if you get them cheap...
rb20det plenum and intake
rb20det ecu
rb25det rocker cover
HKS 264 cams
rb25det turbo exaust manifold
32mm external wastgate
rb25det auto tranny + tailshaft
and an aftermarket computer to suit rb30det hybrid
bill
If anyone here wants panels I would be interested in a dressed R33 GTR front cut. Once here who ever wants the panels could grab them as i only want the running gear.
Once you have an idea of prices let me know as i may be able to help you out with shipping. If i cant i could put you onto the right people ;):D
  • 4 weeks later...
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
