  • Replies 45
nah man sorry im more looking for a family car like a v8 of some sort or an xr6 turbo if anyone is interested
umm dude ou got offed a senator and a orion you sed no to booth ! wot car would you like i got a vn ss would swap manual spool difts sik
nah man u miss understand sorry, i mean i want a newish family car with a bit of guts like a BA or newer xr6 turbo or xr8 or a VY or newer v8 make sense sorry for the confusion and it wasnt a aurion it was a camry sportivo 4 cylinder...........
1996 BMW 535i E39 V8
130,000km
full grey leather interior
the extras that it comes with thats not currently fitted are..
comes with clear euro style lights (red on bottom clear on top)
a set of angel headlights
chrome grill
stock headlight covers
comes with full service history log book at BMW
The car is in A1 condition
Thread cleaned...
HOWEVER - matt_40rulz - you are basically crying wolf. And well, i don't like that.
So some hard truths time for you
1. You are not clear on what car you want to trade for.
2. You are indecisive and argumentative when people are offering up trades/questions/ideas
If you genuinely want to sell your car and/or trade then you should be posting as much info as possible to alleviate any communication issues.
So next time think before getting worked up and then hitting the report post button to drag my busy behind in here to clean up your own mess.
Thanks
Admin
  • 3 weeks later...
  • 3 weeks later...
swap for toyota celsior, pearl white, quad cam v8, full leather interior, electric everything, airbag suspension with aftermarket height controller, 20" chromies with new rubber excellent condition
And a honda cbr250 rr with custom black paint with blue pearl flames, full aftermarket exhaust, and work done to the carby, unrestricted model, does not sound like a 250
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
