hey guys hows it going..long time member first time 'newtopic' :devil: the deal is i bought a pretty exspensive ecedy clutch kit and fly wheel last year.. i had a heaps of money and asked the guy i want the best clutch u can get for the street so he got me and Exedy cermic button one with a exedy lightweight flywheel and i changed my fork and pivot and also bearing housing in the box.. so everything was knew to do with the assy and also had the master and slave rebuilt with stainless tubing...just wondering if it cood just be that some water has gotten in the whole in the side of my gear box?? there is a big whole in the side from the pervious clutch exploding bolts..because this clutch shouldnt be slipping.. ive got 300rkw and this thing is rated to like heaps!! any help would fine, thankyou heaps..sorry about this rambling on but i am just really anxious ive wasted all that money...
If you've been daily driving the button clutch, as suggested above, you will burn out the material quickly. It's made to grab and that's it. You slip it too much and you'll wear it out as fast as a standard clutch.
if its a unpsrung hub you shouldnt be driving daily, best for racing
a light flywheel, = more slipping to get moving on hills from standstill, wearing the clutch faster
riding the clutch pedal,,,even the slightest bit on the pedal will kill the clutch/throw out bearing
out of alignment /bolt torque not even will kill the clutch
oil on the plate = failure. water on the plate will warp it
oily hand prints will hot spot it ending in failure
hope this helps a bit ?
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
