hey all
im slowly slowly tidying up my engine bay, and just wanted to know if there was any idea out there that might help with the look of my engine bay....
here is what it used to look like:
and now:
what do you guys think?
is there anything else i should do?
ive also put the engine cover back on too
https://www.sau.com.au/forums/topic/281812-any-ideas-for-engine-bay/
I would only use 3 colours to detail your engine bay. They would be black, chrome and colour that suits your car. The only prob is its hard to stop once you start :)
Id look at getting a cover for your battery and fuse box, braided lines with silver fittings or colour that suits your car, one piece pipe for your pod and tidy up the wiring(re tape)
Or you could go 2GUUP style ;)
+1
rocker covers have been painted, just a silver colour, nothing to flash, but it looks much better than what they did,
and the engine cover is still that black/silver/red.
and suggestions colour wise for the engine cover?
ive heard that if you braided line you have to do everything braided line......is this true? or could i just do like the main hoses and whatnot you will be able to see?
what about getting the silicon hoses for the radiator? what are your thoughts on that? id go blue, because the colour for the car is blue (hence why she has the blue bits on the intake piping)
also no point in spending over $1000 on a greddy plenum when my car is non turbo :whistling:
ive painted my extractors too
I'm thinking bout spraying the NEO cover. Too many hoses and what not messing up the look of it otherwise :down:
how about enclosing your pod (cover over top)?
im not too sure what colour to do the neo cover tho? i think if i do it blue it will be too much of an overkill with the blue silicon hoses on the intake pipe
arnt braided lines illegal in adelaide, like defectable?
not sure to be honest
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
