hey guys
anyways, hasd my skyline bout a month now, and loving it.
only thing is the odometer says 110,000kms, now i know it hard to tell how accurate some are but i think mines pretty bang on and the whole car itself looks as though its only done this amount of kms.
anywho, i know the guy before my had the timing belt/all belts change and replace at about 98,000kms or so, but i was just wondering if there is anything i need to worry about, like doing a rebuild somtime soon? maybe for just the bottom end?
also, what sorta price range am i looking at?
cheers
https://www.sau.com.au/forums/topic/282009-think-i-need-a-rebuild/
Get a compression test done, leakdown test would be handy too.
I don't know the specs for the RB25, but the RB26 at least I know, unless there is more than 14psi difference between cylinders, or any of the cylinders are below 128psi.. then you need to seriously plan a rebuild, I would expect the RB25 to be slightly higher or slightly lower psi wise.. thats when you know you need a rebuild.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
