  • Replies 109
Yup :(
Gup - Powercruise.com wrote:
"Hi krystal
There are no club deals in 2009 because it was such a mess last year so I
have decided everyone can look after them selves for entries and people like
yourself can get in early and sort out where everyone might want to camp
with each other on the day"
https://www.sau.com.au/forums/topic/282156-powercruise/#findComment-4752684
  • 3 weeks later...
  • 4 weeks later...
so what was the go here? i seen a few skylines running around but not much action as far as sauwa was concerned? i spent my time hanging with the silvia wa guys, had a blast (wasnt driving was passenger with friend from silwa) but still me thinks poor effort. Props to the imports tho giving it a go against some huge v8's!
https://www.sau.com.au/forums/topic/282156-powercruise/#findComment-4874255
Read post #4, there was never any plan to be there.
https://www.sau.com.au/forums/topic/282156-powercruise/#findComment-4874337
or do we need the clubs approval before we can do anything at events like this an represent sauwa? surely not? i mean at events like these i think we should be present and getting the name out there and known aswell as having fun as a club with some sort of presence. i had a blast and it woulda been nice to look at members cars out there. just i dunno felt a bit left out as a skyline driver :D
https://www.sau.com.au/forums/topic/282156-powercruise/#findComment-4874378
that is my point.... its a good event...why not?
Read post #5. The organisers specified that there would be no club entries... It's probably too hard to govern
'Club approval' will never be given to attend an event on it's behalf. The club either involves themselves or doesn't
Edited by Topaz
https://www.sau.com.au/forums/topic/282156-powercruise/#findComment-4874566
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
