Seems like a convenient spot? What's that existing line there and can I just remove it or should I run a t-peice?
Otherwise is there a better spot to do it?
Car is a 95 r33 gts25t and I'm new to turbos so a little help would be much appreciated. :rofl:
Also I know I'm gunna cop shit for this but I bought a small shift light that doubles as a digital tacho as well. Was gunna chuck it on top of my steering coloumn. Where's the best place to grab the ignition signal from?
Thanks guys :D
https://www.sau.com.au/forums/topic/282588-can-i-plumb-my-boost-gauge-here/
That is fine to T from there. That line is for the standard boost guage in the cluster.
Tacho signal from ECU pin number 7 from memory.
Legend!
Now I just gotta be patient while I wait for my package from justjap.com :rofl:
If I don't care about the factory boost gauge in dash... Can I just run a straight line from it?
If not... where do I get the t-peice from?
Yes you can run your line straight from it & the dash boost gauge will simply no longer work...
But you should be able to get a T-piece from any decent auto-parts store.
Also on my R33 there was an unused vacuum/boost hose connection at the front of the plenum with a rubber cap over it, that's what I used for my boost controller.
The easiest way to route the vacuum hose through into the cabin from either spot is down through the front right guard with the wiring loom.
Have fun!
the autometer gauges come with a t-piece. Depending on what gauge you got it might come with one. just wait for it to turn up and see whats in the box
otherwise just plumb it straight from that line and forget about the stock gauge if you dont want it. mine's read wrong ever since i put my aftermarket boost gauge in but its there so i may as well leave it functioning haha
I was looking at that route before when I was tidying up engine bay. might just do it
The gauge is not autometer it's their cheaper product autogauge...was sort of an impulse purchase because the price was right.
http://justjap.com/store/product.php?produ...=267&page=1
I think it's like a defi knock-off. smoked face. heard a few complaints that they're hard to read during the day but I will make my own decision.
gotta be better then my current situation of manual boost controller + no gauge..
thanks fellas, will try and keep it off my mind til the parcel arrives. then see what's in it and make my decision from there. :rofl:
Edited by dave_rb20
Have fun!
On mine that front plenum connection seems to go to a charcoal cannister. Is it worth disconnecting this and bending the hose around to a U joint and reconnecting it to bypass this? Or am I wasting my time?
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
